Bumper alignment
Old 03-06-2011, 03:39 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Originally Posted by 503C43 ////AMG
Looks like you will need to pull the front bumper off and reset the guide rails, your rear bumper looks like it is only sagging in the rear and you might be able to unbolt the bolts in the back, pull your bumper up and tighten them with out removing the bumper and resetting the guide rails. The guide rails on the rear bumper are on the side not in the rear, the rear is held up by 4 bolts that go into holes in the rear. Taking off either bumper is EASY and resetting the guide rails is easy too.
what is involved exactly in "resetting the guide rails"? is there some spec that we are to follow, or is it a trial and error process?
Old 03-06-2011, 05:54 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
There are some specs per the WIS but if you move the guide rails as far up as they will go your bumper is as flush as it gets, it is really easy
Old 03-07-2011, 06:38 PM
Thx. I'll give that shot.
Old 03-14-2011, 09:45 PM
i finally got around to realigning my rear bumper, or at least the rearmost portion of my rear bumper. looks so much better. it's not flush (and i've been told that it's actually not supposed to be flush), but the gap is now even all the way around. before, the gap on the back part of the bumper was twice as wide as at the rails (no exaggeration). i didn't reset the rails bc i was too lazy, but if i did, im sure the gap wouldve come down even more. but it looks good (enough) as is now. thanks for the tips!
Old 06-28-2012, 07:01 AM
amg801's Avatar
C43 AMG
im sorry for this question but what is the "WIS" that has been referred to in this thread numerous times cheers
Old 06-28-2012, 07:43 AM
(W)erkstatten(I)nfo(S)ystem or something like that. It is an electronic information system used by the dealerships, it shows how to remove/install EVERYTHING on MB cars.
You can buy it on Ebay among other places, it is very helpful if you are working on your own car.
Old 06-28-2012, 08:02 AM
  #32
amg801's Avatar
C43 AMG
503 thanks for that now i know what it is cheers, im just going through the sagging bumper saga at the moment. Today i took the bumper off and both of the brackets on the side are cracked so i will order a new bumper support tomorrow. With the guide rails that are on the car you can unbolt them and adjust them to close the gap right?
Old 06-28-2012, 03:16 PM
  #33
That's what I did, unbolt the guide rails and slide them as high as they will go and bolt them back up. the damaged bumper support is the culprit though, once you change it you will see.
Old 07-17-2012, 11:47 PM
  #34
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
Is this the guide rail, or the support bracket??
Old 07-17-2012, 11:50 PM
  #35
Same thing, loosen the 2 screws, slide it up, and tighten the screws.
Old 07-18-2012, 12:18 AM
  #36
nd4spd13's Avatar
Aaaahhhh that makes much more sense now...
Thanks man
Quick Reply: Bumper alignment
