Weighed my car today
Imagine if our cars weighed about 3010 LBS (the weight of an enzo)
but we would still only have less than half the power (302 hp < 651 hp although we are much closer in the torque department 302 lb·ft < 485 lb·ft) but I can only imagine shaving 1470 LBS would shave a second or 2 off our 1/4 mile times
I found this in an article
SPECIFICATIONS
Base Price $ 53,000
Price As Tested $ 55,065
Engine Type aluminum alloy single overhead cam
24-valve V8Engine
Size 4.3 liters / 260 cu. in.
Horsepower 302 @ 5,850 rpm
Torque (lb-ft) 302 @ 3,250-5,000 rpm
Transmission 5-speed electronically-controlled automatic
Wheelbase / Length 105.9 in. / 177.4 in.
Curb Weight 3,448 lbs.Pounds Per Horsepower 11.4
Fuel Capacity 16.4 gal.
Fuel Requirement unleaded premium (92 octane)
Tires Michelin Pilot SX Front: P225/45 ZR17
Rear: P245/40 ZR17
Brakes
front/rear vented disc / vented disc, antilock,
traction control and Electronic Stability
Program traction enhancement standard
Suspension, front/rear independent double wishbone & coil springs/
independent multi-link, AMG suspension calibration
Drivetrain front engine, rear-wheel drive
PERFORMANCE
EPA Fuel Economy - miles per gallon city / highway / observed 18 / 22 / 18
0 to 60 mph 5.9 sec1/4 mile (E.T.)14.2 sec
Coefficient of Drag (cd) 0.32
So I am confused..... I am going to snap a pic of the door jamb and post it. Maybe we can clear this up.
Went out and snapped a pic and when I looked further it is the GVWR (Gross Vehicle Weight Rating) not the GVW (Gross Vehicle Weight) The GVWR is the maximum weight the car can hold not how much the car weighs.....
The scale was OFF significantly to say the least.... I know of another weigh station close by and I will try there in a couple days and repost the CORRECT weight.
