How to change spark plugs in 95 c36 amg?
Subscribe
Aug 10, 2010 | 05:57 PM
I take the 3 regular plugs out but then there are three metal screws that hold the rest of the plugs in i believe. Do i unscrew these or what?. I dont want to hurt the car any ideas?
Reply 0
Aug 15, 2010 | 05:14 PM
yes, you remove all the plug wires and the three coil packs as well. be warned though, if the wires are old, they could be damaged during removal and will cause misfires when you put it all back together.
Reply 0
Aug 15, 2010 | 11:47 PM
Quote: yes, you remove all the plug wires and the three coil packs as well. be warned though, if the wires are old, they could be damaged during removal and will cause misfires when you put it all back together.
Ugh. Truth.
I'm thinking I should inspect and re-craft that whole end as well. Just for ****s and giggles.
Reply 0
Aug 16, 2010 | 05:53 AM
Good idea and safe practice to change your plug wires at the same time so as to avoid possible problems later down the road
Reply 0
Aug 16, 2010 | 08:16 AM
Quote: Good idea and safe practice to change your plug wires at the same time so as to avoid possible problems later down the road
Just to make it clear to everyone else: the faulty wiring in question is NOT the spark plug boot, which is what is implied in the quoted reply above. It is the wiring leading UP TO the coils themselves that deteriorate from heat.
It is the actual engine harness ends.
Reply 0
Aug 17, 2010 | 10:54 AM
Correct about the harness. On the M104 there are only three spark plug wires. The other three spark plugs are directly under the coils and there is a long connector under the coil. Those connectors can be troublesome. I have replaced several over the years.
Reply 0
Subscribe
Currently Active Users (1)
