sunroof buggyness
Old Sep 6, 2010 | 02:39 AM
T-cles's Avatar
1995 c36 AMG
sunroof buggyness
everything worked fine and then all of a sudden the sunroof will only tilt up; it wont go back down. I used a torxhead in the little spot under the dome lights to manually crank it back down then started cranking it to slide it back (open) and the more it went back the harder I had to turn it until it was most of the way slid back and I couldn't turn it anymore by hand. But then when I pulled back the switch the motor opened it the rest of the way open, and was able to close the sunroof again until it was closed all the way. But now it wont slide back again. Has anyone worked with the sunroof mechanism and might know what is causing this buggyness? the motor works fine but the fact that the position of the sunroof effects whether or not the motor can move it and in which directions makes me think that maybe something is getting jammed up in the motors attachment to the sunroof. The switch might be a culprit too, the drivers side one of the two dome light switches sometimes stops working.
Old Sep 6, 2010 | 02:47 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Have you tried to re-sync it? Here is a post I found about re-syncing the sunroof:
All you have to do is re-synchronize the sunroof. Run it all the way back, you may have to click it several times to get it all the way back, then press and hold the switch in the up position like you would be opening it to vent until it starts to move. This will close the sunroof and then raise it to the vent position. Continue to hold the switch for about 3 seconds afterwards, you will hear a click sound which is confirming it is synchronized. Also when you are holding the switch, some are 2 position switches. If this is the case, only press it to the first position.
By the way, this also works for the windows if your window ever stops working on the one touch mode.
Old Sep 6, 2010 | 08:59 PM
Did you figure it out?
Old Sep 17, 2010 | 09:52 PM
T-cles's Avatar
1995 c36 AMG
It's in the shop atm because a flex joint on the driveshaft busted. I'll try it as soon as I get the car back.
Old Sep 17, 2010 | 11:57 PM
Please post results after you try the re-sync
Old May 24, 2012 | 02:31 PM
illmaticnyc's Avatar
1999 C43 AMG
the follow up is key. my sunroof has been tw itchy. ill try this at home tonite and tell you guys
Old May 25, 2012 | 10:31 AM
1999 C43 AMG
confirmed. worked beautifully.
