c36 rear rotor vented hard to find
Old Sep 6, 2010 | 05:03 PM
florent78's Avatar
c36AMG
I've got some difficulties to find rear rotors
on ebay, I only find solid rear rotor in 290mm / 10mm
I check on my car and I've got vented and visually arround 280mm/300mm and 20-24mm thickness
looking for slotted rotors
can't find them
I've got the feeling my rotors are c43 vented rotors
is it possible ?
thanks for you're help
PS :
front are 4 pistons
a seller tell me correct ref for front is :
H WA 202 421 01 12
I can not find rotor dimension
is it 316mm 28mm thickness ??
Old Sep 6, 2010 | 06:07 PM
jayrasheed's Avatar
1995 C 36 AMG; 1992 W124 300E (M103 Ex Mosselman TT KIT) was 320hp @10psi now stock :(
can't find them
is it possible ?
PS :
front are 4 pistons
H WA 202 421 01 12
the rears on a c43 are 300mm ones. ur car prolly has the smaller 278mm vented ones.
the fronts as per the p/n listed are 320 mm x 30 or 32mm cant recall wich of those it is.
Old Sep 6, 2010 | 06:17 PM
florent78's Avatar
c36AMG
ok
thanks for those precition
so c36 do not only have 288 or 316mm front discs, they can have 320mm
do you know some other mercedes model who share the front or rear discs ?
will be easier for me to find the correct discs
thanks again
Old Sep 7, 2010 | 12:25 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
if the rotors are still oem, take the part number of the edge of the rotor. u may need take the wheel off to do so. go to the dealer and ask what car the part number matches to. might be easier to find similar rotors for the other cars listed by dealer this way.
Old Sep 7, 2010 | 02:03 AM
jayrasheed's Avatar
The rear disks are from the W124 E420 ie the V8. But the fronts are from the W129 SL 600 V12, with a modified center hub, thus the sl disks cant fit the AMG. u need the AMG disks.
