C43 camshaft details
I don’t know how much detail you want but for the 2001/2002 CLK430, the intake centerline is 108, intake duration is 199, at .050 lift it’s 162, valve lift is .356, and lobe lift is .239. Exhaust duration is 227, at .050 lift it’s 184, valve lift is .374, lobe lift is .251 and overlap is 78. As you no doubt guessed, they have 1.49 rockers (intake and exhaust).
However still havn't found any references and specs for the "standard AMG ground cam. Still searching....
