drilled rotors install
I actually have a pair of 4-piston S500 calipers that will bolt up to a W202 that would utilize 330mm calipers - if any one is interested. I got them before I pulled the trigger on the C32/C55 345mm calipers for my C43. PM if interested, need to unload for cheap!
I didnt order because according to her, they order "blank" rotors and they drill them upon request. I was afraid id end up with some cheap "made in china" stuff that would warp and overheat easy.
Im ordering two stock 330mm c230 rotors for the front and two rear stock c43 rotors for my car tonight. Total is $240 and this is through my friend's dad's shop. Wish I could get you all the same deal but I cant
They are made by Zimmerman(sp)
What pads do you guys normally run??? I still need pads...
Just to shed some more light on this company, the company that sells the rotors and does the machining is Brakenetic. The rotors are made by Centric, the parent company of Powerslot and StopTech. From what the salesman told me, the rotors are made in China as blanks. Brakenetic then drills, slots, and zinc coats the rotors per the customers request and sends them out. My rotors are drilled, slotted and coated, and all 4 are internally vented.
From first impression, they look good. The drill holes and slots look fine, I believe the drill slots are chamfered (sp) so it's not so rough on the pads, and they seem to be built solidly. I've had the rears on for almost 1000 miles and can say nothing bad about them. Put the fronts on today and so far so good. I do drive hard, and plan to track the car a bit, so hopefully we'll know how well they hold up in hard conditions.
PJ: I love the Akebono Euro Ceramics. I've had those on my back axle and Jurid on the front for about 3k miles, and the difference in dust is ridiculous. I'm tempted to say the dust on the back wheels is only extra that's been flung off the fronts
Zayed these Centric rotors, drilled, slotted and internally vented weigh in at 9.7kgs front and 6.8 for the rear
normal drivers me/you do NOT use the brakes as those on the race track.
I drive my car hard on country roads; my brakes never failed me in 40 years of driving.
it is like adding a bug shield thing it decreases wind drag.
now, more pistons are good. but the come with drilled/slotted rotors,,still use factory breaking total surface
I honestly think the only advantage these have over our stock rotors is the price
Now if we were to track the car, im sure those drilled rotors would stay cooler
While they may take away surface area, they more than make up for it with added bite and an escape route for water, gasses, and heat.
But still, unless it's a race car where every kg matters, and every little bit of heat dissipation means a better time, it is just for looks, and knowing that your car has a little more of a "performance mindset"
