c55 rear brake fit c43??
Old Feb 2, 2011 | 09:56 PM
Motorsport3's Avatar
Dynocomped C43K, 08 X5
Hi members!! I've been doing some search but couldn't find the answer.
So, do c55 rear brakes (whole thing) fit c43 rear???
Old Feb 3, 2011 | 12:41 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Yes, they fit, minor modifications to the backing plate otherwise bolt on upgrade
Old Feb 3, 2011 | 06:27 AM
DRBC43AMG's Avatar
Would changing the back plate and using one from the C55 be a better and cleaner option than cutting it up ??
Old Feb 3, 2011 | 12:36 PM
Saaboteur's Avatar
eclectic assortment of cars
But typically removing the backing plate requires the complete hub removal, even though it's only held on by two or three small bolts. Complete PITA. Better just to cut it and not have to deal with the hub removal. The difference would be like 5 minutes with a pair of tin snips or a dremel type tool, as opposed to (likely) a couple hours at least. I know which one I would prefer!
But aren't the rear brakes on C43s and C32/55s the same anyway? For the fronts, sure, cutting or removal of the backing plate is required.
Old Feb 3, 2011 | 04:34 PM
jayrasheed's Avatar
1995 C 36 AMG; 1992 W124 300E (M103 Ex Mosselman TT KIT) was 320hp @10psi now stock :(
I think they r the same. both have a 2 piston calip with piston size 42mm, both have rotors of size: 300mm X 22
Old Feb 3, 2011 | 08:30 PM
popey24's Avatar
C43 AMG 5.5 - 396.4HP
There are a lot of models with 300x22 rear disc. They are all more or less the same. So there is no advantage.
Old Feb 4, 2011 | 02:24 AM
Thanks guys!!
I think maybeI will just get some rotors, ss brake lines, and hawk pads and call it a day.
Please someone let me know if theres easy brake upgrade.
I've already spent $$$$ (almost twice more than what I paid for the car) on my car since I got it last Nov, and I still need to do some brake upgrade. Then I need to get front and rear camber kits, and then real carbon fiber overlay...... f(cuk.. what should I tell my wife...
