Woah, woah, woah...
Old Feb 10, 2011 | 11:47 PM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
Woah, woah, woah...
So, it's been long talked about on this forumn: foglights. Differences between the switches on 36's and 43's, ways to turn certain bulbs on on the 36's quad foglight set up, and how NOT to turn on the rear fog when turning on the apron fogs. Thru all the arguments that have arisen out of these discussions, one thing has always been clear for C36 owners: You can't have the headlight fogs AND the apron (bumper) fogs on at the same time, that is the whole point of those $50 relay boxes attached to the headlight harnesses. But I was checking out a YouTube vid of a euro C43 and look what I saw...
My mind has been blown
Anyone have any insight? Is this a Euro thing? Or am I just freaking out over 20 mins of electrical DIY?
Attached Thumbnails Woah, woah, woah...-screen-shot-2011-02-10-10.35.30-pm.jpg   Woah, woah, woah...-screen-shot-2011-02-10-10.34.57-pm.jpg   Woah, woah, woah...-screen-shot-2011-02-10-10.35.37-pm.jpg
Old Feb 10, 2011 | 11:58 PM
cherokee94nz's Avatar
2006 C55
Just checked mine, the fog lights work with the lights on both beams. The switch has to be pulled out to the second click. Mine is a euro model shipped to Japan new.
Old Feb 11, 2011 | 12:00 AM
2006 C55
opps The rear works when the apron light is on. First click lighs in main, second rear and apron lights.
Old Feb 11, 2011 | 12:02 AM
AMG_C36's Avatar
1997 C36 AMG
What's the best way to disable the rear fog? Always wondered about this...
Old Feb 11, 2011 | 12:04 AM
2006 C55
Not sure, but have a look at the bulb, it may be a twin filiment. Get one of the same value as the others, then will not be brighter.
Old Feb 11, 2011 | 12:08 AM
2006 C55
Yes i just looked it is a double filiment bulb. Replace with bulb of same watt both sides. Then will not be as bright.
Old Feb 11, 2011 | 12:57 AM
Steve155's Avatar
1999 C43 AMG
cherokee94nz - you anywhere near Nelson? I was just there visiting my sis in law - noticed you were from NZ....
Don't mean to HJ the thread...
Old Feb 11, 2011 | 01:00 AM
2006 C55
No i am part way up the bottom of North. South Taranaki. Under Mount Egmont. Will be through Nelson next month on a tour.
Old Feb 11, 2011 | 01:02 AM
Steve155's Avatar
1999 C43 AMG
cool - was my first time to NZ, lots of fun - will be back later this year for another visit.
Old Feb 11, 2011 | 01:03 AM
Steve155's Avatar
1999 C43 AMG
I think I have the time down now...it's Friday 8PM?
Old Feb 11, 2011 | 01:04 AM
2006 C55
7pm actually. Send a message next time you are in Gods own country Steve.
Alan
Old Feb 11, 2011 | 01:07 AM
Steve155's Avatar
1999 C43 AMG
i'll do that - have a good night - I'm off for now - enjoy!~
Old Feb 11, 2011 | 11:44 AM
Outlawlatemodel's Avatar
2006 c230
hmmm
Old Feb 12, 2011 | 01:43 AM
nd4spd13's Avatar
No it's not the highbeam. If you look closely, his low beams are on, his headlight foglights, and his apron fogs. I'm aware the fogs work with the highbeams.
Also best way to get rid of the rear fog is to take out the fuse labeled "rear fog" under the hood! This may be different on other years, but on the 95 this fuse controls the fog portion of the taillight, so the bright second filament doesn't come on, but everything thing else works exactly as it should
Old Feb 12, 2011 | 02:59 AM
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
Pull the damn wire to the rear fog. That simple: was a know fact few years ago when I had my c36.
Old Feb 12, 2011 | 05:37 AM
2006 C55
The bulb for the rear fog lights is a 2 filament bulb. One is rated a higher wattage then the other. Put a equal wattage bulb in and will slove problem.
Old Feb 12, 2011 | 12:03 PM
nd4spd13's Avatar
Those Are usable, but a fuse is definitely the easiest to take out and put back in at your will. And if you put a single filament in but turn the rear fog "on" won't it burn out the bulb much quicker.
