c36 changing tensioner belt and serpentine need help
c36AMG
hi
I've got some difficulties to remove the tensioner belt (and belt itself)
I remove easily the upper nut for the damper
but tensioner system same special :
I've got a big torx nut for the tensioner belt (T55 or T60)
and unable to screw it or unscrew it
I should turn clockwise or anticlockwise to remove it ?
if someone can give me some indications to remove this F... tensioner belt
thanks
thanks
c36AMG
I finally remove the TORX crew
anticlock (normal) to remove it
now I've got difficulties to remove the last nut for the water pump (bottom left nut)
I'm blocked cause tensioner is in front of the nut
and unable to remove the tensioner (sames a nut is behind the DA pump pulley)
any help ?
any help ?
