unwinterized- overheating, heat blows cold, air bubbles?
Old Mar 20, 2011 | 02:24 PM
silence's Avatar
sounds like airplane
How would you troubleshoot?
Seems that it running the heat with the coolant system open and letting the bubbles work their way out isn't doing it.
Is the coolant even cycling through the whole system? Can this be a thermostat issue?
I replaced the thermostat about 3 years back.
Old Mar 21, 2011 | 03:34 AM
DRBC43AMG's Avatar
I don't have the solution, but can suggest you check the two way heating valve just by the bulkhead which flows the water left and right. It sometimes sticks closed. Could be also heat sensor which has not woken up yet.
Old Mar 21, 2011 | 10:46 AM
silence's Avatar
would that valve sound a bit like a woodchuck trying to pop and gluck it's way out of the middle of the dash as it sticks and unsticks while I drive?
Then as it unsticks a bit would it add more air bubbles, drink more of the coolant down etc. and 'cause mayhem?
I spent some time with it yesterday and got an improvement, but it's still not perfect.
Is there a trick to adding coolant to these cars without getting air bubbles? I've tried all the normal stuff- perhaps this valve is partly to blame.
I'm just glad it's not a wrecked water pump (it seems), or a blown head gasket (it seems) or a bunch of other things.
Old Mar 21, 2011 | 02:24 PM
DRBC43AMG's Avatar
Hmmm, I'm not sure. Just wondering if there is a bleed tap somewhere in the system which needs to be opened to get the air to escape?
Old Mar 25, 2011 | 12:30 AM
silence's Avatar
there must be!
I've managed to get it to the point of working now- but it still "burps" some air every once in a while (engine temp needle bounces and/or sounds from that location in dash)
That said- It's not overheating now and it's totally "summerized". Got to go out for a bit of a spirited drive yesterday... soooo much fun! Now just plan to do the front brakes and add a factory bike rack then drive her a bunch this year!
