suspension mods
Old Apr 27, 2011 | 10:15 AM
  #51
slowsky's Avatar
2011 C63
shocks/springs combo, start fresh...did you get it from parts.com?
Old Apr 27, 2011 | 02:37 PM
  #52
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
springs from vogtland-na.com
shocks from tirerack.com
Old May 8, 2011 | 04:43 PM
  #53
pfleger81's Avatar
1998 s320, 1995 e320 cabriolet, 1995 c36, 1988 230ce 5 speed, 2004 CL55 AMG
i got the springs from parts.com thanks for the direction, looking around for shocks now going to order the eccentric bolts. Im going to take it to my guy to have a look and give some recs on what could be changed. will probably throw in some bushings as well.
Old May 12, 2011 | 12:36 AM
  #54
AMG_C36's Avatar
1997 C36 AMG
Euro spec spring for the c36
Anyone know if there is a euro spec spring for the c36??? This is exactly what I am looking for
Old May 12, 2011 | 08:51 AM
  #55
I would imagine they do as the bumper height requirements are different in Europe... Call up MB and ask
Old May 13, 2011 | 12:28 AM
  #56
MarcusF's Avatar
2002 CLK430
When measuring ride height on a 911, it’s common, using a tape measure, to measure from the ground past the center cap on the wheel, to the fender lip. When people give those numbers (in inches or mm, front and rear), everyone knows exactly how high the cars sits while still. The same procedure may prove useful when measuring a 202. That would tell someone where euro spec springs sit in relation to U.S. springs, H&Rs, Vogtlands, or anything else. That may also help those with questions about pads and how much springs settle.
Old May 13, 2011 | 12:46 AM
  #57
RANDY_P's Avatar
1996 C36 AMG, 1970 LeMans Sport, a truck
Originally Posted by MarcusF
Holy crap now THAT is a 964!
Old May 13, 2011 | 01:52 PM
  #58
AMG_C36's Avatar
1997 C36 AMG
any suggestions/reccomendations of where to call? not that i have had bad experiences at my local dealership, but i know some people have better experiences at other dealership that might be a bit more mod-friendy.
thanks
Old May 13, 2011 | 02:45 PM
  #59
DuaneC63's Avatar
AMG GLC63. Audi R8
Call CEC in Irvine or Santa Monica. That's were I got my spring and shocks for my C43.
Old May 13, 2011 | 04:18 PM
  #60
AMG_C36's Avatar
1997 C36 AMG
i know of CEC, but were your parts super expensive? no doubt CEC carries high quality stuff, but usually that type of place is pretty pricey as well. thanks for the help
Old May 13, 2011 | 05:21 PM
  #61
thanks
Call as many as it takes
Old May 14, 2011 | 01:51 PM
  #62
Headgone's Avatar
95c36
Do they have any coil over set up for the c36?? i love the coil overs because i love how they feel on my E36. I dont think a spring & shocks set up gets better than coil overs. I was looking @ the KW but they r a little pricy! what about the D2?? I was told it only can fit on the c280 & not the C36. Isnt both cars the same body? In the BMW world anything that fit the regular 3 series suspension wise fit the M3's!! Please explain. Thanks in advance
Old May 14, 2011 | 02:20 PM
  #63
As far as I know there are no coilovers for W202...
Old Feb 4, 2012 | 12:29 AM
  #64
hoontastic's Avatar
99 c43 / 99 ml430
I can't seem to pull up the e55 springs on parts.com anymore. Does anyone know of a good source for them?
Old Feb 4, 2012 | 01:08 PM
  #65
PM MarcusF, IIRC he had a list of dealerships that could source them cheap
Old Feb 4, 2012 | 01:28 PM
  #66
hoontastic's Avatar
99 c43 / 99 ml430
Thanks. Also, I wanted to get my short list together for shocks to pair with it. Obviously there are the two versions of bilsteins. Is there just one oem choice or is there an alt version that should/could be paired with the lower e55 springs? Also I noticed that the h&r kit used koni yellows. Although I haven't read much about people using the konis. Is/are there another brand(s) that I am still missing?
Old Feb 4, 2012 | 01:49 PM
  #67
KW makes a kit with springs and shocks but it is $$$$$$, it is supposed to be really nice. OEM are made special for AMG by Bilstein, the HD's are as close as you can get without buying the OEM. The OEM are $$$$$$$$$$.
Old Mar 18, 2012 | 09:47 PM
  #68
96mbc36amg's Avatar
1996 c36
koni shocks & springs
Has anyone used this combo on a 96 C36? Any scraping problems?
