Car turning over but not starting
Old Sep 7, 2011 | 04:02 AM
DRBC43AMG's Avatar
Originally Posted by 98 MBC43 AMG
yes thats correct but how do i go abt getting the gunk outta the tank
You may need to remove the tank from the car, remove the plunger and flush. Check inside for rust. Check also for outside rust as you could end up with a nasty leak. You may need to get the tank changed if the condition is too bad.
Old Sep 7, 2011 | 08:20 AM
98 MBC43 AMG's Avatar
98 MBC43 AMG
hey fells can a fuel filter cause a fuel pump to go and if the fuel filter keep getting clogged.
Old Sep 7, 2011 | 09:39 AM
DRBC43AMG's Avatar
Sure thing. If the filter is clogged and no fuel getting through, the pump will be working dry and most likely burn out and die (expensive too)
Old Sep 21, 2011 | 11:33 AM
mercedesmd's Avatar
1993 300E
Hi, I have a 1993 300E. My problem is that the car will crank but would not start.
I checked the fuel pump relay behind the battery. The fuel is good.
Listen for the clicking sound of the motor for the fuel pump when you turn the key to the "ON" position. No clicking sound.
My question for you is, " Did you hear any clicking sound of the fuel pump motor when you turn your car key to the "ON" position.
My car has 2 fuel pump under the car. Just can't believe that both fuel pump are not working.
Wondering if my problem is just a simple fuel filter change.
I do notice that when I tried to go uphill, my car do not have much power.
Is that a sign and symptom of the fuel pump going bad?
Old Sep 21, 2011 | 11:44 AM
98 MBC43 AMG
check the fuel filter first that was my problem wen you take it out blow threw both ends to see if air goes threw each side. read my texts on here you will understand good luck
