C43 tranny failure
Old Apr 15, 2012 | 04:10 AM
cm60k's Avatar
Originally Posted by nd4spd13
For the stock rad or the B&M one? I read a bit on that link and the B&M one has a built in thermometer to one of the hose couplings. It's nice because to wire it up, you only have to supply a constant and a ground and the rad will switch on the fan when the temps get high enough.
Don't know about the merc one though
Yes sure,, MB uses that auto sensor switch #: "006 545 15 24", since "92", in many models......
ZAYED,,
Old Apr 23, 2012 | 12:50 AM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
Originally Posted by 503C43 ////AMG
Shifting from "D" to "4", "3","2", or "1" is no longer mechanical but rather electrical. After you shift into "D" the shifter no longer moves the shift linkage but uses electrical signals to tell the tranny to shift.
I have completely removed the shifter from my car and taken the shifter apart and have no idea what could cause this , it makes no sense
AHA!
He explains the problem with it. Still don't totally understand how a rusted arm could cause this if it's all electronic, but at least that solves the question of what the problem with the tranny was.
Old Apr 23, 2012 | 02:20 AM
DRBC43AMG's Avatar
Great video and simple explaination. Thanks
Could you post it also in this section: https://mbworld.org/forums/c36-amg-c...deos-w202.html
Check out also the MBCluster's web site
Old Apr 23, 2012 | 03:58 AM
cm60k's Avatar
Very good find, Thankss for shared.......
ZAYED,,
