1995 c36- just bought it. Tranny a bit weird
Old Sep 10, 2011 | 10:07 PM
chimchamp's Avatar
1995 c36
Thumbs up 1995 c36- just bought it. Tranny a bit weird
160k. My dad had a 95 brand new... I know this car well. Tranny is not shifting into 4th without me expressly lifting off. It wont shift in third at redline either.... This sucks. I do have a cel but havent checked it because my buddies $13000 snap on modis wont recognize c36. Lol.... I came from porsche nightmare to benz nightmare....lol
I dont want to build a trans. I see one on ebay but who the hell knows what it is. Appreciate any good help.
Old Sep 11, 2011 | 06:42 AM
DRBC43AMG's Avatar
Get a tranny filter and oil change first and see what happens. Check also the oil pan for metal filings and such like.
Old Sep 11, 2011 | 09:11 AM
chimchamp's Avatar
1995 c36
thanks.... was headed there this week. I do see a metallic shimmer in the oil I extracted :\
Old Sep 12, 2011 | 09:53 AM
jumph4x's Avatar
W210 DRFT BNZ
Again, just like the engine wiring harness, the throttle body AND the transmission wiring harness are both going to be shot.
You have to rebuild all there, which is surprisingly easy to do.
Old Sep 12, 2011 | 10:11 AM
chimchamp's Avatar
1995 c36
cool. SO I will remove them..... My maf plug was wasted in a small burn...and I don't know the order of the wires to the pins on the maf/ that's the only place I forsee trouble. Otherwise, solder up new wires and insulate/ package well and should be good. worst harness i've ever seen! been playing with cars a while- had lots of different ones.
Old Sep 12, 2011 | 01:33 PM
RPB's Avatar
RPB
Agreed, do not hear too many issues w/ the 4spd trans. Typically the upper harness goes bad due to engine heat but this could be due to a bad trans harness. I have tried many expensive code readers that do not work on my 95. Sears has one for $50 that works great, Actron model# 9125, car has to be running for it to work.
Please post when you found out what the culprit was, GL.
Old Sep 12, 2011 | 02:07 PM
chimchamp's Avatar
1995 c36
where on earth do you plug it in? my buddy has a really expensive snap on modis that woudnnt read through the port near the ecu... is there another?
AH HA [edit]... i see it
