Cams and head porting.
Old Dec 17, 2011 | 12:57 PM
whipplem104's Avatar
1990 300ce supercharged and intercooled
I took a spare head over to a shop yesterday. The guy thinks there is about 7% gain in the exhaust valve bowl. Maybe a little on the intake. I am looking at about 900.00 for a complete valve job and bowl porting and machining the top of the head for much bigger lift. Stock head can not have more than about 10mm of lift without machining for clearance. Also springs are at coil bind at a little over 10.7mm of lift. New springs required. Custom weld up on the cams and regrind at around 700.00.
I was thinking of having profiles done for N/A applications at the same time.
Old Dec 18, 2011 | 02:54 PM
Super B's Avatar
'97 c36
Very cool. You should snap some pictures when it gets back..
