Replaced cruise control switch now SRS light is on.. need advice
Old Feb 20, 2012 | 09:51 PM
hoontastic's Avatar
99 c43 / 99 ml430
I carefully removed the steering wheel with airbag and replaced a switch on the steering column. I carefully reversed my actions and plugged everything in making sure to go slow and get everything back in properly. The horn works the switch works... everything is fine.. except the srs light keeps coming on. I took the steering wheel back off and double checked all the connections to the airbag and it appears to be plugged in properly. Am I missing something? Does the system detect when the airbag is unplugged and store a code? How can i reset it? Should I try unplugging the battery for 30 minutes?
thanks!
Old Feb 21, 2012 | 12:15 AM
hoontastic's Avatar
99 c43 / 99 ml430
update: I unplugged the battery for about an hour.. srs light still coming on. Looks like i will need a capable scan tool then, to clear it?
Old Feb 21, 2012 | 12:21 AM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
STAR reader should be able to pinpoint exactly where the fault is. Did you turn on the car at all when the airbag was unplugged?
Old Feb 21, 2012 | 12:36 AM
hoontastic's Avatar
99 c43 / 99 ml430
yes, stupidly. I wanted to hear the radio while i worked.
Old Feb 21, 2012 | 12:38 AM
nd4spd13's Avatar
Can't blame you Does yours not work when the key is removed though??
I remember reading when I had to take off my wheel that whatever I did, to not turn the car on while it was unplugged. Hopefully the STAR should be able to clear it. I imagine it's just an annoying stored error right now.
Old Feb 21, 2012 | 01:54 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
You turned on the car with the air bag unplugged!
This is the root cause for the SRS light, you will need to have it reset using the STAR system to eliminate the SRS light.
Next time you want to listen to some tunes bring in a boom box or something
