ML55 & C32 Calipers
Old Mar 9, 2012 | 03:57 PM
amgmaster4343's Avatar
C43K AMG 436 rwhp moded ML55 AMG 190td 190e 2.3-16v moded EK9 Civic
ML55 & C32 Calipers
I'm sure this has been asked in the past but does anyone know if the Ml55 calipers are the same as the C32? I think they are both 345mm
Old Mar 9, 2012 | 04:28 PM
cm60k's Avatar
Exactly, both uses 345mm Rotors with same pads, ML55 uses M14x35, the C32/C55 uses M12x45, if you want to use the ML55 calipers in the C32/55,
you just need to put 2mm sleeve to the caliper screw holes........
ZAYED,,
Old Mar 9, 2012 | 05:58 PM
ZAYED,,
Ok, thanks.
Old Mar 9, 2012 | 06:12 PM
see I was thinking the ml55 calipers would work on the c43 since the c32 ones do and I though that the c32 and ml55 were the same.
Old Mar 11, 2012 | 03:21 AM
DRBC43AMG's Avatar
ZAYED,,
I always thought the c32 were 330mm
Old Mar 11, 2012 | 04:34 AM
cm60k's Avatar
C32/C55 sharing same brake setup:-
Front Rotors: 345mm & Rear Rotors: 300mm
ZAYED,,
Old Mar 11, 2012 | 09:15 AM
320 dreamer's Avatar
2003 porsche 996 turbo
ZAYED,,
the length of the 2 different bolts tells me the caliper offset is different by 10mm. this could be an issue when mocking up the caliper on the rotor to the c class mount holes
Old Mar 11, 2012 | 11:49 AM
cm60k's Avatar
Good point,,, but we can’t surely confirm that,, its also depend to the screw hole thick in the caliper it self,, it
should to put the caliper in the in the knuckle to see how many mm needs to clear & balanced the Rotor with the
caliper,{easy job}........
ZAYED,,
Old Mar 11, 2012 | 11:56 AM
ZAYED,,
when i tried to mount the sl55 rear calipers they looked identical to the s600 rear calipers but upon closer inspection the mount ears were 1/2" wider and 3/8" shorter than the s600. s600 was a bolt on with sleeves in the mount holes but the sl55 required custom brackets to make them fit. im guessing this would be a similar issue. look at the s600 front calipers. 4 pot and will prolly be a better fit
Old Mar 11, 2012 | 12:57 PM
cm60k's Avatar
Which SL55 you mean..?, is it W230 or R129.......??, also which S600..?, W140 or w220 or W221.....??
ZAYED,,
Old Mar 11, 2012 | 01:48 PM
2003 sl55 and i think 2002 s600 not sure would have to look up the part # from my setup on the car
Old Mar 11, 2012 | 04:04 PM
cm60k's Avatar
In generally the "S/CL" uses the same brake setup & "E/SL" uses the same brake setup & "C/CLK/SLK" uses the same brake setup & "ML/GL/R" also uses the
same brake setup,, if you want to put "E/SL" calipers into "S", you definately needs to fab. F/R brackets to fit correctly,, (as examples): i done
some setup in "4" models:
1) W124 E500 1993 with 8/8-pot Calipers & Rotors from "R230 SL55 2003-2006 & W220 S55 2003-2006"
2) W210 E60 1997 with 6/6-pot Calipers & Rotors from "W204 C63 2007 & R171 SLK55 2005-2009"
3) W202 C43 1998 with 8/4-pot Calipers & Rotors from "R230 SL55 2003-2006 & W204 C63 2007"
4) R129 SL500 1999 with 6/4-pot Calipers & Rotors from "R171 SLK55 2005-2009"
*discuss that before in: https://mbworld.org/forums/c36-amg-c...e-upgrade.html
ZAYED,,
Old Mar 11, 2012 | 05:42 PM
DRBC43AMG's Avatar
Very nice and I forgot about that thread Good for bringing it back to the surface
Old Mar 11, 2012 | 06:13 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
same brake setup, generally,, if you want to put E/SL calipers into S, you definately needs to fab. F/R brackets to fit correctly,, (as examples): i done
Attachment 230343Attachment 230344
Attachment 230345Attachment 230346
ZAYED,,
What modifications were needed to fit the 8 pot 4 pot setup on the C43?? fronts were from SL55 and rears were from C63??
Now I am going to have to add these to my to do mod list and I have brand new calipers
Old Mar 11, 2012 | 08:31 PM
anyone have part # for the ml 55 front calipers?
Old Mar 11, 2012 | 10:56 PM
cm60k's Avatar
Left#: "163 421 17 98 or 19 98 or 21 98 or 23 98"
Right#: "163 421 18 98 or 20 98 or 22 98 or 24 98"
ZAYED,,
Old Mar 12, 2012 | 03:35 AM
cm60k's Avatar
It needs more mods. if you want to go with 8/4-pot,, and also its heavy,, in my opinion; the best & easy setup with
bolt on(without any mods.)from SLK55 AMG 2005-2009 6/4-pot........
ZAYED,,
Old Mar 12, 2012 | 03:57 AM
DRBC43AMG's Avatar
I agree 8 pots is a bit overboard. For example, the biggest upgrade made by Brembo and sold for the c43 is 6/4
Old Mar 12, 2012 | 06:36 PM
these were the # given to me from a set im looking at. look like c32 calipers supposed to be from a ml55
PART # 20.7233.02 , # 20.7046.04 i know those are brembo # if anyone can confirm they would work on a c class or slk ill buy them and make someone a good deal
Old Mar 16, 2012 | 07:06 AM
cm60k's Avatar
Yes it should work,, but it may need some washers to correct the caliper with rotor balance, soo easy job.......
ZAYED,,
Old May 9, 2012 | 04:15 PM
Ok heres the deal. The ML55 calipers bolt right up, but the caliper towers are to short so you have to use a 12.5" to 12.8" rotor. However it would be a great upgrade for a C230 or C280. The C32 and C55 have the longer tower point which make the 13.6" rotor fit. So Im going to take some pics and try to sell them. So now we all know, well somebody had to try this right.
