Difference Between K1 And K4?
I need the Door Lock Control Module RIGHT.
I found one a used one that all the connectors are the same but on the STICKER in the unit it says K4. On my module it says K1. And they are different part numbers but like I said they match perfectly..
Whats the difference between K1 AND K4?
Thanks. Btw, the part number I'm looking for is 208 820 1226. If anyone has one for sale let me know!
Also, can anyone explain this. My right side window will not work, than I disconnect the battery for a few seconds and connect again and window works. 2 days later it stops working and I do the same as mentioned. If the module is shot why does it work after I disconnect the battery?
00 C200 & 00 C55 & 06 SLK55
Kxx, means; the production place & the company code # (which prepare & produces products for MB),, the "208 820 12 26" is an old #,,
the new #:"210 820 76 26",, honestly, i don’t have any idea what Exactly these Modules controled of.......
ZAYED,,
You may have a bad main switch (4 Windows with Trunk release and side Mirrors adjustment), but im NOT that sure, if that switch causes this kind of
issues.......
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
ZAYED,,
