Abs light ????
Old May 28, 2012 | 12:20 PM
Johngoped's Avatar
1998 c43 amg
Abs light ????
on my c43 amg whenever I go past 20 mph my abs light and bas light turns on have any of u guys ever had that problem and do u guys know how to erase it any help would be appreciated thanks
Old May 28, 2012 | 01:46 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Try replacing the brake pedal switch, it's cheap and easy to do and will eliminate one variable.
Old May 31, 2012 | 02:15 PM
Johngoped's Avatar
1998 c43 amg
Any other solutions ????
Old May 31, 2012 | 02:39 PM
cm60k's Avatar
Is the third brake light working....?
ZAYED,,
Old May 31, 2012 | 02:47 PM
Johngoped's Avatar
1998 c43 amg
Yes
Old May 31, 2012 | 02:48 PM
cm60k's Avatar
Then You may have a bad Wheel speed sensors, or the teeth in the hub(which gives the sensor magnet signal) dirty or goes weak,,
and sometimes you need to reset the ECU & Throttle to clear the lights by MB Star........
ZAYED,,
Old May 31, 2012 | 02:56 PM
Johngoped's Avatar
1998 c43 amg
What do u mean by third brake light ??
Old May 31, 2012 | 03:04 PM
cm60k's Avatar
The rear light under the rear window, when you press the brake, the light should work,,
as example: http://www.ebay.com/itm/MERCEDES-W20...-/230697020303
ZAYED,,
Old May 31, 2012 | 03:24 PM
Johngoped's Avatar
1998 c43 amg
Ok I see thanks
Old May 31, 2012 | 03:34 PM
cm60k's Avatar
If the brake light works fine, diagnosis the car, if you got a bad speed sensor code, just clean the hub teeth & clean the sensors as
well,,
i tried that "3" years ago, its working fine.......
ZAYED,,
