1997 C36 Head gasket question
Thanks the help!
Or is it mixing?
If it ain't mixing and just seeping on the usual spots then you are fine to just remove the head and replace the head gasket and assemble, that's it, ASLONG as you know the engine hasn't been over heated that is.
If it actually is mixing and it did overheat I would do a complete head gasket job.
The first one is the least expensive I would say $500-1000,
The second would be more $1,200-$2,000 depending if you want to replace other wear items when you are in the engine at the same time. Good luck and keep us posted!
Thanks a ton for the help!
