Motor cycling sound?
I have tracked the sound to the trunk on the passenger side. When I pull back the trunk liner I can see a dark foam block covering something. That something is making the noise and I'd like to identify what that is before I pull it all apart. Does anyone have an idea what is behind that foam block?
From what you are describing it sounds like you have a leak in one of the air lines which causes the pump to continue to cycle.
Thanks for the help
Mike
Thanks for the help!
