I've done some searches here and other forums and have found plenty of information on '95 C36 brake discs, but little on the pads. I know I'll be needing new pads soon and have run into the same problem that others have had with selecting the correct choice for '95 year only front brake pads.
-What is the OEM front brake pad number for '95 only?
-What is a preferred brand aside from OEM?
-Is there a general read across number that exists from after-market applications? I.E. 96-97's have the number "561" in them
-Do you run a specific pad on your '95 for a reason?
The car is a daily driver so I'd rather not go with a real agressive pad and chew up the expensive rotors. Not too concerned with brake dust either, I clean the wheels on a regular basis.
Thanks for you help,
-Dave
-Dave
SPONSOR
-OEM number should be 005-420-02-20 for a 1995 C36
-There are three other brands: Jurid, Pagid and Textar.
-Dave
The main thing specific to the '95 is the rotors. They are directional, typically run about $180/200 for each side.Originally Posted by Elkidmino
I've done some searches here and other forums and have found plenty of information on '95 C36 brake discs, but little on the pads. I know I'll be needing new pads soon and have run into the same problem that others have had with selecting the correct choice for '95 year only front brake pads. -What is the OEM front brake pad number for '95 only?
-Dave
Thanks for the replies. I'll update the thread when I order and install a set.
Currently Active Users (1)
