Fitted after market air filter, now running on only 5 cylinders?
I'm by no means a mechanical genius, but the only way a cone filter (or any air filter, for that matter) affects your MAS is by allowing a greater volume of air (which is the very reason to run a cone or aftermarket filter) to be measured.
It seems like you have added some parameters to the mix. What do you mean when you say, "I changed it for my spare"? You'll have to be more specific.
Well it had a new BOSH air sensor on it, I then fitted a cone filter, gave it a few revs, sounded good.
Then took the cone filter off and went back to factory layout, (airbox)
The next morning I started the car and it ran lumpy, slight missfire.
I thought I must of damaged my air flow sensor after reading previous posts on here, so I fitted a spare one I had from my last C36, from what I remember it was working correctly.
I also cleaned my spare before I put it on with brake and clutch cleaner.
It did seem to run a bit better, the revs did not drop so much, but it seems its not running on all 6 cylinders.
Like its only running on 5.
I cleaned my original sensor put it back on and no change.
So I'm back to my spare, When I unplug the air sensor it still runs lumpy so I am thinking it something else.
Was running perfect before I fitted the cone filter. Wish I never bothered now.
First thoughts are coils, I am plugging it in tomorrow to see if any codes come up.
Lot's of variables here (changing MAS's, installing cone filter, etc.). I'd agree with w202love, reset your ECU to start. If it works I'd say you changed parameters within the ECU the moment you attached the cone filter. However, you switched back to your stock airbox while the ECU was still in 'learning mode', which threw things off.
BTW, I know it's common to clean MAS's and MAF's with brake cleaner (c'mon, we've all done it), but I read a thread somewhere from a knowledgeable person who made a great argument for using MAF sensor cleaner.
Reset that ECU and report back what happens.
Turned out to be 1 dodgy ignition coil, so I replaced the plugs and coils, she now runs like a dream. Happy again now.When I plugged it into my friends laptop, it came up with fault codes 107 Dwell angle cont at stop of ignition
The ecu was advancing the timing to much.
and 090 Camshaft timing acuator Y49??
She runs sweet now, thanks for your input guys, so glad to have this forum to aid fellow Mercedes owners
So, the big questions is, "are you gonna try running that cone filter again?"???
Haha... not sure now, maby I sould leave it standard, maby drill the box, but not sure....
