C43 Bilsten sports, Vogtalnds, 17s, Spring Pads?????
Old Dec 17, 2012 | 12:33 PM
vlad957's Avatar
1998 C43 Amg
I was wondering if anyone has the same setup as me. Bilsten Sports with Vogtland springs and 17 inch amg rims? My question was what spring pads did people use on this setup? I need my car a bit higher. Its too low. Its running on the stock spring pads.
Old Dec 17, 2012 | 02:16 PM
KJI3jflarryfe93's Avatar
do you have factory shox or aftermarket billies?
if you have stock pads they should be the thinnest 1 nib pads.
others have used #5 front and #4 rear with Vogtlands, try this setup.
I need to know if this combo looks good with stock factory shox and Vogtland springs.
Next spring I'll have my Voggies installed with stock shox.
Old Dec 17, 2012 | 02:49 PM
vlad957's Avatar
1998 C43 Amg
Yah there the bilsten sport shocks not the stock ones. I guess Ill try that setup can you give me the part number for #5 front and #4 rear? If you know it by any chance? And are people running those spring pads on 18s and 19s? You think that spring pad setup will be good on 17s????
