My C43 finally lowered Part 2
Ride hide slight lower than expected. Was told 1.5" drop looks more like a ~2" drop. Not sure what pads I have but they are the same ones that came stock. (anyone know what comes stock?) Will changing pads make noticible differnece? Negative Camber! My rear tires look nothing like KWiK's. They have negative camber and when the Goodyear shop did alignment and tried adjusting the camber they were not able to get it in spec (no more room for adjustment) I was told no need for a camber kit from Brabus and now shop telsl me I need one. My shocks: Install guy tells me I need new shocks, that the bilstien (sp?) are not capable of handling the lower springs and are bottoming out. There is this clunking sound (as if something is bouncing around in the truck) coming from the rear shocks. I did some drive tests over speed bump (one tire at a time) and this sound is coming from ONLY the rear driver side shock. With only 35K miles, can my shock have gone bad? (got warranty). Some feedback, comments, opinions would be helpful in shedding some light on this.
Oh also Brabus told me warranty will not be void with these springs. Ture or false? Will i need to get the old springs back in if my shock is bad and needs replacing?
Will post pictures later this evening
Hope you get this worked out.
remember, I'm running 255/35/18 in the rear on a 9" wheel so it fills the wheel well a little more.
just 2 pennies
Can you remember me what parts have you installed on your car?? Springs and shocks...
I'm looking to lower my car for the same reasons as you but the roads are loaded with cracks and holes here and I want to keep a certain level of comfort...
Thanks!
PS
I have the specs from the alignment shop for the camber. They are all out of spec. Fronts are at -1.2 and rear -1.9 and -2.1. Specs are 0.8 to 0.2 i think. #4 pads come in today and so lets see what happends with that.
-MOE
Silver, doesnt look bad at all. Incline is definately messing with you. I think when you put the #4's on you will be happy. Plus 18in rim will make large difference aswell, start shopping
-MOE
KWiK regarding yr post about the camber correction bolt, what is that and where can i get it and $ and how can I do it or do i need to have an install shop do it? My front will still have some neg camber so I'd like to correct it.
Thanks for all your help guys!
Silver, did you leave #2 pads up front? Please get some pics up when complete a.s.a.p please. And on level groud this time!! Thanks bud-MOE
I will re-measure the rear with the #4 in and post the numbers up. Pic will be taken ASAP and posted tomorrow AM.
ALSO!!!!! if you want to see the full sized image of any picture copy the url link and add .orig.jpg to the end and will show up in 1280x960 size (for better detail)
BTW I have a set of the #4 pad. If any one wants to buy them from me (incase you cant get them from your dealer or for what other reason,) let me know before i return them. I paid $17 for the two so it be the same price and then whatever shipping would be.
