And just like that, no more C43.
Well, I hit a snag in the repairs. Shop calls me saying they had it on the frame pulling machine to check for any frame damage. When they went to drive it off the machine, the key wouldn't turn in the ignition. Had to have it towed to the dealer to replace the key before I could get the repairs finished.
I picked it up from the dealer myself. They warned me that all the suspension and steering parts had been replaced/repaired, but that it badly needed a complete setup and was probably way out of alignment, but that it was safe to drive back from the dealer.
Boy were they right.
All the way home I noticed the ESP stabbing rear right brakes randomly and flashing the ESP light at me. I disabled ESP for a bit. Out of curiosity I turned ESP back on, only to have the yellow warning lights for ABS and ESP. I'd pull over and my ESP switch would have no effect. Turn car off and restart, and it would go back to normal with the random ESP jolts until eventually the lights came back on and ESP was seemingly disabled. Research online indicates it was just the ESP and steering angle sensor detecting that the suspension geometry at the front was WAY out of whack and was tricking the system. Supposedly, it will all go away once the suspension and steering are adjusted and set up at a shop. Let's pray.
I snapped a quick pic of it in its sad, unfinished state.
Pretty sure they missed something rather important in the front suspension. It behaves normally unless I'm accelerating from a stop with heavy throttle. Took off from a red-light with about 75% throttle. As the front of the car picks up from the take off, I hear a CLUNK in the suspension up there, and as the front of the car comes back down I hear the same CLUNK again. Absolutely no idea what that could be.
