C36 Sway bars upgrade
Old Jun 3, 2013 | 03:42 PM
w202mylove's Avatar
Carlsson CM60 EX:C36AMG'96
Hey guys I need your guys help on this.
The suspension on my euro c36 is stock, I want to upgrade just for road use. I already have got the Vogland 35mm lowering springs and Koni's adjustable schocks in my house ( not installed). And I was wondering if the H&R sway bars are a real upgrade compared to stock amg? what will be the positive effects of the upgrade?
Old Jun 4, 2013 | 03:08 AM
KJI3jflarryfe93's Avatar
did you get the twintube adjustable shox or the monotubes?
these are the 2-tubes
Koni gelb einstellbar 8041-1315SPORT VA
Koni gelb einstellbar 8041-1316SPORT HA
did you get a good deal on these shox?
can you link the shop?
i need to compare pricetags
can you take some pictures of your koni's for me?
i'm getting those soon.
thanx
Old Jun 4, 2013 | 06:33 AM
w202mylove's Avatar
thanx
Hey I bougt these: http://www.ebay.de/itm/120537385789?...84.m1497.l2649
Should be pretty good shocks for my car right?
Nr. vorne rechts : 8041-1315Sport
Nr. vorne links : 8041-1315Sport
Nr. hinten rechts : 8041-1316Sport
Nr. hinten links : 8041-1316Sport
kowalski: Did you also get the Vogtlad springs? Already intsalled them? I'll get you some pics tomorrow!
Old Jun 4, 2013 | 02:03 PM
you got the Koni twin tubes.
seller you linked sometimes gives 5% discount.
I'll get the same shox, this way it will be more of lazy comfortable adjusting the settings to my liking.
what thickness pads are you getting to avoid rubbing?
I will pork my Vogtlands onto my car when I get the Koni's.
I will also put all new rubber bushings and suspension rods on rear axle to synergy my front suspension upgrade from last year.
I hope I get what I'm lookin' for?!
more road stability in speed of a carthief
Old Jun 4, 2013 | 03:32 PM
w202mylove's Avatar
I'll also replace the rubber bushings and suspension rods on rear axle lol. Have no idea what pads to get, what pads will you run?
why don't you upgrade the swaybars, really would like to know if it will give me a noticeable positive effect.
Old Jun 4, 2013 | 04:38 PM
hey budski
I bought what our american friends got for their Koni/Vogtland set up #5/#4 pads
I need to measure my stock swaybars to see if they are thinner than H&R's Mars bars?
if stock Swayzes are thinner, then H&R might be a güt upgrade?
Here's some input, from H&R webiste
no info about C36.
http://www.hrsprings.com/application...ts/25/430/1999
