HVAC insanity
First off, when the fan is on the vents blow constantly out of the defroster, the left and the right side. The center vents have nothing coming out of it. If I am not mistaken the vents are controlled by vacuums and hoses, and I have a feeling that a hose has become brittle and broken off; however, I have absolutely no idea where those hoses are located. Can someone enlighten me (pics definitely would help) as to where I can find the connections for vent control?
Second, the A/C is no longer operational. It could be one of the following reasons and I need help in identifying where the problem stems from: Freon levels are low, A/C evap temperature sensor is dead, AC condenser is dead, or maybe something else I am not even aware of. I did check out the climate control diagnostic (actual values) while the car was on, and the refrigerant pressure in bar was 8 bar. The evaporator core temperature sensor was somewhere around 170 degrees fahrenheit.
I have previously searched this and other forums for similar issues but did not find find the answers I needed. Advice from the experts would be much appreciated.
Hope this helps!
Hope this helps!
Going to spend all tomorrow trying to fix that now WITH the vent control...And I have a 6 hour road trip next week
I believe one or two of them can be replaced if you're careful and feel like removing steering wheel, both knee bolsters, and the entire dash face and trim (radio, ccu, etc). The real fix is removing the dash and replacing the pods. Not a job for the faint of heart at all. Took me 4 whole days to replace the 2 failed bellows in mine, but it restored all proper flow.
I also had to replace my AC evaporator. Pray to the mighty Lord that you do not have to do this. Aside from replacing the dash, you have to evacuate the system and plug it ensuring no ambient air gets into it. You have to drain coolant because the heater core is coming out, too. Then disconnect an absolute nightmare of vacuum hoses, wires, cross members, and irreplaceable plastic clips and snappies all over the place.
Then you get to put it all back together! Most shops charge $3k for this job.
Diagnosing no-cold-air is much easier and cheaper. Step one is to perform diag using the built-in method on the ccu. That will tell you status and readings of sensors, pressures, RPMs of compressor, etc. Assuming the CCU is functioning correctly (it usually is) it should tell you all you need to diagnose.
If not, you need to get some manifold gauges and hook them up to test the pressure yourself.
I can explain the variables at that point, if it gets to that.
God speed.
Sorry it's not a great shot, but hopefully you can see here how just above the foot vent there's a collection of vacuum tubes. I figured that's the best place to start, as I'm pretty sure that's where they go to the individual "pods" for each vent. Then I imagine there's another one of those on the drivers side. This piece I'm referring to acts as a distribution block from the big green tube coming through the firewall on the pass side and the air vents.
Are you saying your fan stopped working after the kneeboard removal? It's the big plastic bit under there with two clips, you probably just bumped the plug when you were down there
God speed.
Thank you very much for the photo; I will be tinkering with those vacuum tubes tonight in hopes of getting the center vents to start blowing air again
Refer to the attached pic: is the cover in the red circle what you were talking about?Edit: I think I understand now; it seems that the US spec c43 will not have the vacuum distributor under that cover, but behind the passenger side front fender liner... I'll be checking this out as soon as I get back. Fingers crossed that it's there, and that the hose just fell out of place.
