AC not blowing cold...
...and I can't get that damn "EC" button turned off. I ran diagnostic codes with the "REST" button, but I need to review further to see if anything is out of whack.
Shouldn't I be able to turn the EC button off just by pressing it and thereby engaging my AC compressor?
Help! It's going to be in the upper-90's here!
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Indeed, check that you have gas in the system. In most cases they will inject a traceable dye to check for leaks together with lubricating oil for the compressor.
Cheers, gents! This is what I thought needed to be done. I'm thinking of trying one of those, "DIY" kits, isn't this the inlet valve I should be using?
![](http://i32.photobucket.com/albums/d33/johnny_chingas_90254/007_zps1a1ef82c.jpg)
Probably cheaper to have a specialist look at it and replacing the gas you need the weight and not volume.
OK, had the system checked by my local, trusted shop. The refrigerant was rather low, .19 lbs and the system holds at least 1lb. more. However, after re-setting the system, they could not get the compressor to power up. In other words, the damn 'EC' light is still on!
Need to take the car to an import specialist since my normal mechanic does not have the necessary equipment to check the compressor issue. He also told me I have a 'medium'-sized leak at the compressor.
Should I source a compressor at a junk yard if one is available?
Well it's the compressor.Buy a new one which is not that expensive.Unfortunately the dash basically has to come out...IT'S A NIGHTMARE JOB..Its a 3k job
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
I stand corrected, dash removal for evaporator.Let us know how you make out.
I'm really hoping Kowalski and Sulaco are correct. I'd rather not replace a compressor and just deal with a couple of 0-rings. But I have to see why the unit will not receive power or power on, something's not right with the compressor.
I'll certainly update everyone when I get it fixed.
try the cheapest solutions first, get it on star to see codes if compressor is dead?
it's cheaper to replace some orings or a hose than a compressor.
if there's a leak, doesn't mean your compressor is bad.
look for used newer style compressor from junkyards if you have to replace?
1999 C43 AMG, 2005 E55 Wagon
Unit will not turn if pressure is below a certain point. That's a feature to prevent compressor failure from turning with nothing to compress. Only way to test it is to supply a direct 12v to its power source on the clutch to see if it engages. Also refilling the system at the low side port with some fresh r134 will cause it to engage once it reaches minimum required pressure.
My mechanic said they did add fresh R134 and the compressor would still not engage. Also, they detected a "medium-sized" leak at the compressor, but they didn't say if it's a simple matter of replacing the o-rings?
00 C200 & 00 C55 & 06 SLK55
Is the Expansion valve & condenser valve & gas tank ok...?,
did you check the electronic components..?,
(Air temp. sensor - Tank temp. sensor - Gas tank sensor - Evaporator sensor - Blower regulator)
ZAYED,,
ZAYED,,
