Speed Density "SD" vs Mass Air Flow "MAF"
Old Sep 12, 2013 | 06:12 PM
cm60k's Avatar
Just been curious, if anyone have an idea,
if we can cancel the MAF, and use the speed density to calculate the density of the air by measuring the temperature air and manifold pressure....??!!??
http://www.pcmforless.com/index.php?...ning&Itemid=56
ZAYED,,
Old Sep 13, 2013 | 01:24 AM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
I'd check out what Blackbenz had to do in terms of switching systems to get his Weistec to work.
Old Sep 13, 2013 | 03:45 PM
Pagz's Avatar
C43 w/clk55 Organs
IIRC MAS is more accurate, I ran MAP/airtemp and TPS on my turbo due to pipe sizes and because my tuner was more suited to that, If I had a choice again I would have run a MAS,the ability to change with environment far outweighs MAP,TPS,airtemp.
Edit, also we ran MAP because we did not think the MAS would read 16psi. this was never tested though.
