Caliper painting, and a lot more!!!
Old Mar 30, 2014 | 10:24 PM
88260EEE's Avatar
1998 C43, 05 Mini Cooper s
Doing some spring cleaning, had my rotors resurfaced with some new Hawk pads an cleaning up the calipers
Old Mar 30, 2014 | 10:26 PM
88260EEE's Avatar
Degreaser, wire wheeled brake cleaned, they had some old bad red paint
Old Mar 30, 2014 | 10:29 PM
88260EEE's Avatar
Couple coats of nickel metallic, and a couple coats of clear
Old Mar 30, 2014 | 10:30 PM
88260EEE's Avatar
Hammer coat clips
Old Mar 30, 2014 | 10:34 PM
88260EEE's Avatar
Brake hoses look a little beat so new hoses too, and while everythings out the way, new bilsteins cuz those are leaking
Old Mar 30, 2014 | 10:52 PM
88260EEE's Avatar
Looking pretty good
Old Mar 30, 2014 | 11:19 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Always thought about painting mine brilliant silver and filling in the amg logo with black
Old Mar 31, 2014 | 04:59 AM
Super B's Avatar
'97 c36
Looks nice.
Old Mar 31, 2014 | 08:57 AM
88260EEE's Avatar
I was thinking of doing the AMG black or red
Old Apr 1, 2014 | 06:06 AM
DRBC43AMG's Avatar
Get some SS lines. Improves the pedal feel no end.
Old Apr 1, 2014 | 06:08 AM
DRBC43AMG's Avatar
Painted mine silver and thought about painting the AMG logo black. I gave up coz my hand is not steady enough and in any case once behind the Monos, you can't see them.
Old Apr 1, 2014 | 09:00 AM
88260EEE's Avatar
I was going to do SS lines but can't justify $100 bucks for two small brake lines! Maybe down the line!
Old Apr 2, 2014 | 10:29 PM
88260EEE's Avatar
Old Apr 2, 2014 | 10:30 PM
88260EEE's Avatar
Old Apr 2, 2014 | 10:34 PM
88260EEE's Avatar
Bilsteins, calipers, Hawk pads, resurfaced discs in!!!
Old Apr 3, 2014 | 02:25 AM
DRBC43AMG's Avatar
Looking good!
Old Apr 3, 2014 | 04:42 AM
KJI3jflarryfe93's Avatar
you foggot to paint the rotorhubs, that will be a nice colormatch to your calipers
Old Apr 3, 2014 | 05:38 AM
DRBC43AMG's Avatar
If you decide to paint the hubs which would be a good idea to compliment your newly painted callipers, DON'T paint the front part of the hub. This can cause vibrations and hampers a good contact between the wheel and hub.
I suggest you get a coat of heat resistant clear varnish on your callipers if you havn't done it. That way they will better resist brake dust and other crap generated with braking.
Old Apr 3, 2014 | 05:39 AM
88260EEE's Avatar
True
Old Apr 3, 2014 | 06:09 AM
you mean don't paint the ventilation holes between both attached disc parts?
or where the wheelbearing cap is fitted?
Old Apr 3, 2014 | 06:15 AM
cm60k's Avatar
+1,
Also don't paint the teeth pits (that gives a reading to speed sensor)..
ZAYED,,
Old Apr 3, 2014 | 09:31 AM
88260EEE's Avatar
I did a clear enemal over the nickel to help with the heat and dust!
Old Apr 3, 2014 | 10:37 AM
DRBC43AMG's Avatar
I was meaning to say don't paint the face where the wheel is bolted to the hub. That should only be smeared with copper grease to avoid corrosion.
Old Apr 3, 2014 | 12:16 PM
that place is only greased to prevent wheel getting rusted on
Old Apr 3, 2014 | 04:05 PM
eFifty5AMG's Avatar
2004 E55
I've been thinking of painting my calipers that type of color. What kind of paint did you use?
