EGR Bolt?
Old May 4, 2014 | 05:35 PM
RPB's Avatar
RPB
EGR Bolt?
Hi Guys,
I am trying to remove my EGR valve, but the bolt in the back close to the firewall will not budge. I hit it with WD-40 and lithium grease w/ no results. I am putting 180lbs of body weight on this thing and nothing! I have never come across anything like this, it does have a good amount of rust buildup on it. The one in the front was bad enough but the one is the back is another story! I might have to get a propane torch.
Any other ideas on how to loosen this bolt?? Thanks!
Old May 7, 2014 | 01:43 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
propane torch won't do anything to it.
I've dealt with those alot before, that same bolt. an air hammer with a chisel bit will turn that right out. You'll mangle the head quite a bit but bolts are cheap.
