Also did front swaybar bushings, upper and lower control arms, steering damper, ball joints
Had a lower ball joint stem/pin brake off in the arm PITA!!!!! Had to pull the hole arm and bring it to a buddies shop to drill it out!
Quote:
Did you use Bilstein shocks? sports or HD?Originally Posted by 88260EEE
Did front shocks too
PJmak
close
- Join DateSep 2007
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive05 c55 silver, 98 Imperial Red C43
Liked:421 Times in 315 Posts
Quote:
You replaced the control arms?Originally Posted by 88260EEE
ExploreMember
What pad #'s did you use?
I change mine recently to euros and #1 pads all corner.
Does anyone have the Euro alignment specs for reference when taking it to the alignment shop?
Kept the stock pads for now might change them out later, not looking to go to low!
Where did you get your spring compressor and what brand is it? The one I have is puny and used on Hondas but ima need a heavy duty one now
You need the special Benz one, I borrowed mine from my old shop! They have them on eBay
