Any suggestions..Suspension and rubbing~!
Im having troubles with rubbing on my drivers front fender with my tire. Using 18"Monoblocks off a E55 tire size 225/40/18s and suspension is Eibach Springs and Yellow Koni's on the soft setting. Do I need to get a front camber kit? I heard maybe fender pull would do the trick. Any inputs would be appreciated. Thanks in advance.
PS:
Have a SRS lamp on constantly and once in a blue moon ESP lamp will soon.. Bah..Cheers..
I think if you were to roll them and install higher spring pads youd be fine but i run no pads and i have same size in front and i only rub at full lock but its not that bad at all
