CL600 Calipers?
@popey- thanks, just trying to sort out the confusion and misinformation. Love your headlights by the way. Thank you for your post on that. I'm thinking about following your footsteps and doing the same.
@ everybody thinking about this swap- In general c32 brakes are NOT just bolt on as a lot of people think. This is what's needed to make them work properly-
The hub needs a threaded hole drilled and threaded for the rotor retaining screw. As the c32 rotor is larger and screw hole is further out on hub.
The bolt hole for the brake linings connection block on the caliper frame needs to be upsized and threaded for the w202 factory bolt.
Sprinter van brake lining sensors are needed to adapt to the w202 wiring.
The piston plates need to be swapped to achieve the right piston order with smallest piston first.
longer brake lines are needed as the brake fluid inlet port will be facing down after you swap the piston plates.
And finally your wheels *may not clear your new calipers depending on which ones are on your car.
*HOWEVER* if you don't care about the brake piston order, then all that is needed is the rotor retaining screw in the hub and the upsized bolt hole for the brake lining sensor connection block on the caliper. The rest will bolt on.
@Super B- when you say smallest piston first, do you mean that it needs to be towards the font of the car or the rear of the car? What issues would I run into if they were in the wrong order? And lastly, where did you get new seals for when you swapped the plates, or were you able to re-use the original seals?
I've seen some people say that the rotor must be spaced, I have seen some say that's not the case.... What is the verdict on this?
as far as running them in the wrong sequence i really don't know. Like I said earlier, I've read of people doing it and a guy I know personally runs it that way. If was to take a guess, I'd just say you might get some strange pad wear and a little less performance from the brakes. But I'm not an expert or brake engineer.
The seals between the caliper frame and piston plates are just simple o-rings and reused them as they still looked new.
As far as spacers, I did not have to use them with C32 rotors. A friend with a c280 is using what looks to be the same caliper and rotor as you and he had problems with the rotor contacting the inner part of caliper. I believe the hat on the rotor has a different offset for the SL than the C32 rotor but that could be verified with a part number search.
Imagine the rotor tries to move the pad, but the pad is fixed. So it will cause torque that presses the pad onto the rotor in front end and away from rotor in the rear end.
The different size of pistons is to have same breaking power on all pistons. If you miss, it does not equalize different breaking power but even amplify. So you have almost all breaking power on the first piston
spacing the Rotors is a matter of bolt thickness of CL/S600 calipers comparing to the C32/C55 calipers..
ZAYED,,
He said he was going to have his buddy at the machine shop mill his caliper mounts down a bit to help them clear. I haven't been able to meet up with him since to see what he did. But he did send me some pictures of his ride with the brakes mounted up.
I think he had clearance issue,cause he using a complete SLK350 brakes(calipers & rotors),
he may need to put some washers between caliper bolt hole, to adjust & balance the rotor,
i used a different sizes of washers with R170/W210/W202/W208/W220,,
it's a simple job, with little focus & patience..
ZAYED,,
I am going to go down to the parts store next week and buy just one cheap c32 rotor to use to test fit everything before I start ordering quality parts. I'll report back later. I may also need larger wheels... haha
Definitely, S/CL600 Rotors will be wrong choice, C32/C55/CLK500/CLK550/SLK55, are the best..
ZAYED,,
Still have to wait till the morning to bleed them, I didn't have a helper or a power bleeder :/
when i used CLK500/550 calipers, i put 6mm washers either, means CLK500/550 & CL/S600 calipers are almost the same..
ZAYED,,
