vibration from 20-40 MPH, 1999 C43
Old Sep 28, 2011 | 08:10 PM
JohnnyRock's Avatar
1998 C43 AMG
Good bump, Hoon, I'm having similar issues. I'm getting a slight steering wheel vibration at highway speeds (65mph+), car "pulls" to one side and under har cornering I've gotten "shuddering" and the traction control light on the dash comes on (yellow triangle w/! symbol in the middle).
Old Sep 28, 2011 | 08:14 PM
hoontastic's Avatar
99 c43 / 99 ml430
if i slam on the brakes from 70-10 i get steering wheel shudder.. sh_t doesnt make me smile. Thats the one area where its a distraction in a bad way. Otherwise its more of a nuisance but not critical just a killjoy. I'm gonna start with following the script and just replace the wear parts.. Interestingly I was talking to 5 oh 3 the other day and he mentioned that perhaps the car is supposed to pull to the right... like it was engineered that way.
Old Sep 28, 2011 | 10:02 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
MB's alignment specs will have your car pulling to the right, its like a dead man switch so if you loose consciousness while driving you will not veer into oncoming traffic
Old Sep 28, 2011 | 10:08 PM
hoontastic's Avatar
99 c43 / 99 ml430
Yeah well whatever they were thinking.. its the only vehicle i have had that did that. I have had about a dozen german cars and none of them did that. Do you think its easy to have it adjusted out of the equation? It would make it nicer for roadtrips if it just drove in a straight line.
Old Sep 29, 2011 | 04:51 AM
DRBC43AMG's Avatar
I would recommend checking and changing the steering damper. Had a very vicious shutter in my old W124 when going over bumbs or braking. Very cheap and simple solution.
Old Sep 29, 2011 | 12:18 PM
hoontastic's Avatar
99 c43 / 99 ml430
well it likely needs replacing anyway and its cheap.. looking underneath it looks like an easy part to access. Any gotchas in replacing it?
Old Sep 29, 2011 | 01:33 PM
  #32
hoontastic's Avatar
99 c43 / 99 ml430
Ok should i buy a "Meyle" or "Stabilus/Boge" damper?
Old Sep 29, 2011 | 03:38 PM
  #33
Meyle is what I bought, no complaints
Old Sep 30, 2011 | 04:10 AM
  #34
DRBC43AMG's Avatar
Got mine at the stealership and havn't the faintest idea what make it is. Never has an issue after the change.
Old Sep 30, 2011 | 05:28 AM
  #35
KJI3jflarryfe93's Avatar
stabilus/böge is oem on MB
meyle is aftermarket stuff
Old Oct 4, 2011 | 11:59 PM
  #36
Frank Castle's Avatar
C43
Wobble like that can be caused by a warped wheel. Its out of balance. Have it re-straightened and will be good as new. Swap out your spare and see if it magically disappears and find out which one is need of help (hope only one). Potholes and aluminum don't mix.
Aftermarket wheels? Just checking...if so, you have spacer inserts.
Old Oct 5, 2011 | 12:05 AM
  #37
hoontastic's Avatar
99 c43 / 99 ml430
I have oem wheels that i inherited with the car. Something of interest though with my car is the previous two owners ran the car with les schwap non staggered non hubcentric after market wheels. They were heavy and probably not good for the hub right? That said the oem 17's that are on it do have some curbage.. I thought oem monos were pretty dang tough. Not so?
Old Oct 5, 2011 | 12:14 AM
  #38
C43
I have the monos. Not tough enough for Maryland roads anyway. I had the wobble, got it fixed and had to have another hair line crack welded as it was causing flats. Swap your spare out to the front on either side. i think it was 50 for a weld and 100 for restraighten (or vice versa)
or if you get it right the first try just have a wobble spare and spend nothing
Old Oct 5, 2011 | 12:25 AM
  #39
C43
Is yours lowered? Alignment issues are a little harder if so. I agree with 503 on his call there.
Old Oct 20, 2011 | 11:26 PM
  #40
C43
Did this fix your problem? Was it the wheel?
Old Oct 21, 2011 | 03:59 PM
  #41
Jovsky's Avatar
2000 C230 Kompressor Sport
Sorry to dust this thread off... but my question is kinda on topic so..
When I am driving about 40ish my car exhibits a vibration in the steering wheel. It feels like one of the front wheels is wobbling. Also if I brake hard from a good clip i will feel alot more shaking of the steering wheel. Its not to the point of feeling unsafe but it does not seem right.
I am running oem 17 monos on new tires. My front rotors and pads are new. All the suspension up front is original (car is at 103k). I believe the wobble/shake may start at lower speeds but it really isnt very noticeable until i get going more. I believe the indy that looked at my ac compressor mentioned a balljoint looking bad. Could it be the hub itself? A forum member i talked to about this didnt think the wheel could be bent.
I would love to hear y'all fire off some ideas for me. thanks!
I had a similar experience with my car and brought the car to Downtown LA Mercedes Benz dealer and gave me a printout of what needs to be done. They said I need to change my ball joints because it had excessive freeplay and I need to change the Front Flex Disc because it was cracking. I replaced those and it went fine. Hope this helps.
Old Oct 21, 2011 | 04:02 PM
  #42
hoontastic's Avatar
99 c43 / 99 ml430
yeah my driver side ball joint looks like it needs some attention
Old Oct 22, 2011 | 10:01 PM
  #43
JohnnyRock's Avatar
1998 C43 AMG
What is the front flex disc? What does it do? Got as pic or part #?
Old Oct 23, 2011 | 02:27 AM
  #44
MarcusF's Avatar
2002 CLK430
Mercedes doesn't use u-joints. The use a rubber and metal part called a flex disk at each end of the drive shaft.
Old Oct 23, 2011 | 03:42 AM
  #45
hoontastic's Avatar
99 c43 / 99 ml430
i found this johnny
Old Oct 23, 2011 | 10:16 AM
  #46
Jovsky's Avatar
Yup! Those are the ones. And I find it's cheaper at AutohausAZ. Thanks Hoontastic for the link. Are the parts bought from AutohausAZ reliable? I haven't bought from them yet. Thanks!
Old Oct 23, 2011 | 06:15 PM
  #47
JohnnyRock's Avatar
1998 C43 AMG
Thanks guys. Hoon, from the parts list you showed, BMW calls that a, "guibo"! (seriously)
Jovsky, I've used autohausaz for the past several years for BMW parts. They have great service and prices. They're parts are legit. BTW, I think Meyle would be more than a proper OEM replacement to save a couple of quid.
Old Oct 23, 2011 | 06:17 PM
  #48
JohnnyRock's Avatar
1998 C43 AMG
Agree 100% with you. My ball joint loves proper attention!
Old Oct 23, 2011 | 07:27 PM
  #49
I get the majority of my parts from AutohausAz.com, they are reliable and great shipping too!
Old Oct 24, 2011 | 11:09 PM
  #50
hoontastic's Avatar
99 c43 / 99 ml430
I'm a sucker for the free shipping.
