KW V2 coilover kit
Old Oct 5, 2014 | 04:48 PM
DRBC43AMG's Avatar
I did some driving on normal and highway roads (no twisties though) this afternoon with the new settings. The rear is much more comfortable and softer than before. The front is still a bit too stiff. I'll try the mid-point settings on both front and rear, then I'll take it and fine tune from there.
Old Oct 25, 2014 | 02:20 PM
raw1879's Avatar
Mercedes C55 AMG
My KW V2 Kit came and it was worth the wait. It looks and feels real quality
ive only fitted the kit today and driven the car home. So a bit more driving before I can really feel the difference
Old Oct 26, 2014 | 05:30 AM
raw1879's Avatar
Mercedes C55 AMG
I set both front spring adjusters to 35mm witch is max high. But the rear left was set to 10 mm and rear set to 25mm this is because when I set the rears to same high the left rear was higher I think this is built into chassis
When the new suspension has run in I will corner balance and bring the front down
Old Oct 28, 2014 | 06:52 PM
Pagz's Avatar
C43 w/clk55 Organs
Hey, how did the front look with max 35 set on the adjusters?.
just a thought.. but did you reset all your bushes to the new ride height? Maybe on one side they have been done up while the car is off the ground hence your uneven heights?.
Can you give a comparison of the softest setting vs stock C43 or vs your H&R combo?..
Cheers,
Old Oct 29, 2014 | 03:50 AM
raw1879's Avatar
Mercedes C55 AMG
I think the rear difference on hide hight is normal its about 10mm higher on rear left because of the camber of the road
I'll post a pic of the front before I drop it
Old Oct 29, 2014 | 02:03 PM
raw1879's Avatar
Mercedes C55 AMG
Old Oct 29, 2014 | 03:08 PM
  #32
Pagz's Avatar
C43 w/clk55 Organs
Perfect thanks!
Would you say the max setting on front looks about same height as stock euro springs?
Please let me know how the ride is on softest setting at that ride height?
I would like to use this kit also but don't want it to feel like my Koni/Eibach setup it was too harsh.
Old Oct 29, 2014 | 04:09 PM
  #33
raw1879's Avatar
Mercedes C55 AMG
Originally Posted by Pagz
Perfect thanks!
yes I would say KW max height is same as stock
ill drive over the weekend trying out full soft. I have mine set on 6 all round is drives really not harsh at all
Old Nov 9, 2014 | 03:32 PM
  #34
raw1879's Avatar
Mercedes C55 AMG
Perfect thanks!
Its been a while sine I installed the KW V2 kit on my car now and on 6 clicks from soft (this is where kw recommend you start) the car feels much more compliant less body roll than stock while not being harsh. The best thing ive done to my car was fitting KWs
Old Nov 9, 2014 | 10:01 PM
  #35
Pagz's Avatar
C43 w/clk55 Organs
Thanks!,
Did you try on softest setting?
Old Nov 13, 2014 | 02:15 AM
  #36
_perzbenz's Avatar
cars
Nice. I'm also on KW V2
Old Nov 13, 2014 | 02:32 AM
  #37
Alex33's Avatar
W202 w/ a 5.4L V8
Those look great!
Old Nov 13, 2014 | 01:05 PM
  #38
Pagz's Avatar
C43 w/clk55 Organs
@Perzbenz,
Love that stance!, Really like the amber corners on the 774, must get me a set!.
Have you tried your KW's on softest?
Old Dec 12, 2014 | 01:08 PM
  #39
Pagz's Avatar
C43 w/clk55 Organs
Guys,
has anybody tried there kw on softest settings?
I want to purchase a the kit but cannot find any good write up
Cheers,
Old Dec 12, 2014 | 01:11 PM
  #40
_perzbenz's Avatar
cars
Guys,
Cheers,
Mines on the stiffest so I wouldn't know
Old Dec 12, 2014 | 06:14 PM
  #41
DRBC43AMG's Avatar
Still got all your teeth? ;-)
Old Dec 13, 2014 | 09:51 AM
  #42
KJI3jflarryfe93's Avatar
we want gocart style meaning the stiffest settings
that's what i have on my koni/vogtland setup, car rides very nice and firm perhaps not as good as the KW kit but not far from KW
Old Dec 14, 2014 | 03:08 AM
  #43
DRBC43AMG's Avatar
I agree. It is perfect for the track or highway driving on a perfectly smooth surface, but on everyday roads it becomes spine jarring.
Old Dec 14, 2014 | 02:09 PM
  #44
Pagz's Avatar
C43 w/clk55 Organs
Guys... Is it hard to test these on soft setting? it the adjustment difficult to get too?
Also does anybody know if Koni Externally adjustable are twin tube?
Old Dec 14, 2014 | 02:32 PM
  #45
koni adjustable for c43 are twin tubes, they are a bit heavier than monotube shox which are made for non AMG cars
if you can afford it go for KW, if not Vogtland or H&R is you choice paired with Koni's
Old Dec 14, 2014 | 05:02 PM
  #46
Pagz's Avatar
C43 w/clk55 Organs
I might install my Koni sport 8041 1316 and 1315 and see how they compare to stock C43. also might have them tested this week on dyno ..see how time goes.
Old Dec 14, 2014 | 05:33 PM
  #47
DRBC43AMG's Avatar
The adjustements are not difficult. On the front access is easy and is done on the top of the shock tube with the little hex *** provided with the kit.
At the back it's a little more complicated as access is more difficult. You need to have cut out a small panel in the trunk lining just opposite the top of the shock. The hex *** goes through there, but DON'T drop it, as you will need to remove the lining to get it out. Why? I was victim of some clumsy fingers...
Attached Thumbnails KW V2 coilover kit-s7002900.jpg   KW V2 coilover kit-s7002931.jpg
Old Dec 14, 2014 | 06:48 PM
  #48
mickey13's Avatar
1999 AMG C43
Not a huge fan of yellow, thinking about powder-coating the springs if I get a set. Maybe white or even just powder-coat clear-coat over the bare metal after having the yellow stripped off.
Old Dec 14, 2014 | 08:25 PM
  #49
Pagz's Avatar
C43 w/clk55 Organs
DRB,
Thanks, so it is same adjustment as my Koni 8041 1316 and 1315,I ended up cutting a door for them on my old 202, but thinking about it now maybe you could slide a piece of rubber hose over the adjuster to allow easy alignment of the Allen key and just drill a small hole for the hose through the lining?
Mickey,
Me neither, I would get the springs powered coated black and also have the purple spring adjuster nut re anodized black
Old Dec 14, 2014 | 11:39 PM
  #50
Pagz's Avatar
C43 w/clk55 Organs
Aside from height adjustment,I get this feeling the KW kit will feel the same as my Koni external adjustable's with Eibach pro springs....on normal roads unbearable set to hard, and only just tolerable on soft but no where near comfortable.
