Engine mounts - C43,CLK55,E55,E55K
Old 01-19-2018, 11:20 PM
  #101
blackbenzz's Avatar
haters crazy
Originally Posted by W202AMG
itd be even better if i could find what is hitting or rubbing when i turn hard left... Surely cant still be the starter motor, not only were the new mounts stiffer, theyre 1/8" taller as well.
Something rubs and hits when i turn hard left, and im stuffed if i know what it is, its coming from the right front corner, i cant see anything else rubbing anywhere, so i dont think it is in the suspension.
Is it a clunking noise over bumps? Check your sway bar and make sure it's bolted down
Old 01-19-2018, 11:46 PM
  #102
W202AMG's Avatar
W202 C43 1999
no, quiet over bumps, only when turning left and only under throttle.
Quick Reply: Engine mounts - C43,CLK55,E55,E55K
