Transmission maintenance
Old Nov 14, 2014 | 09:59 PM
maxbhp's Avatar
Hi guys, what is the recommendation to keep our transmissions in tip top shape?
I know the transmission is a weaker part of this car if their is one, and my former C43's transmission grenaded at about 135k miles.
My new car is a 99 and at 43k miles. Is just a tran fluid flush every 10k miles the best recommendation? Anything else?
Old Nov 14, 2014 | 11:03 PM
Super B's Avatar
'97 c36
10k seems early but to each their own. I change mine every 35~40k and check the pressure regulator spring in valve body as well as the wiring harness plug.
Old Nov 17, 2014 | 08:48 AM
DRBC43AMG's Avatar
Sounds reasonable. The flush depends on how the vehicle is driven and the amount of miles/kms.
Old Nov 17, 2014 | 02:57 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
keep good fluid in it (MB), and it'll run a very long time. yes also the electric plug can leak, may as well just replace it for how cheap and easy it is. the wires can wick fluid up into the module and that can be expensive.
Old Nov 17, 2014 | 03:39 PM
Super B's Avatar
'97 c36
Exactly, the dealership sells and I use shell ATF134. first time I changed the oil I went to napa and asked to see what their computer recommends. They said it used dextron.... seemed really strange to me it would use a GM trans fluid so I didn't buy it. (although older BMW's of the 90's used a GM tranny) but really our fluid would be closer to ATF+4. But regardless any oil you put in there should be mb spec approved like benzslo said.
