Help with Identifying Eibach Springs
Old Feb 1, 2015 | 03:03 PM
MPOW33R's Avatar
(For Sale 03 G55), 08 G55K, 99 C43, 04 E55, 05 E63, 91 BMW E30, 05 BMW M3, 05 Audi USP Avant
I searched and searched, but can not determine if these springs are
Eibach
Pro Kit
Sportline
Race
They're Eibachs and I think I ruled our Pro Kit from my search.
TireRack shows Pro Kit as 2545.140 mine are 2545.001
They sit low,much lower in the rear and I want to get rid of
that. Ill do pads but I like a "noticeable" rake so thinking
of pulling out the rears for something taller. Front is just fine.
Driver Front Spring Reads
Eibach KBA 90515
EW 2545.001 VA
Q0 2544
REAR is TOO Low for My Taste
Old Feb 1, 2015 | 03:15 PM
PJmak's Avatar
I use h&r springs and im not familiar with any of those brands but i do know that pads will do wonders. Really no need to swap springs unless the brand you have is prone to sagging over time
Ill bet the front end has thicker pads seeing that he ran 19s on there and is lowered
Old Feb 1, 2015 | 03:17 PM
PJmak's Avatar
What tires are they?(width/height)
Old Feb 1, 2015 | 03:35 PM
MPOW33R's Avatar
The appear to be square and not staggered
19x9 if i had to take my best guess
maybe the rear offset is different - im really unsure as of today.
Wheels are an offbrand named MOVIN
Tires are KUMHOS rears are 90%
fronts are 30%
Old Feb 1, 2015 | 03:38 PM
KJI3jflarryfe93's Avatar
check front and rear pads nibs b4 you get new spring pads.
if you have #2-#3-#4-#5 pad nibs in front?
get the thinnest #1 pad and your car will look much better in a raked style
Old Feb 1, 2015 | 04:04 PM
MPOW33R's Avatar
Thanks but I'm trying to raise the rear I do not wish to lower the front to achieve the rake look. So Ill probably in theory add pads or the tallest pad to the rear before yanking anything out because to my surprise with being so low and on 19s it roses really really well!!
