Driver's Door Key Hole?
Old Feb 25, 2015 | 08:31 PM
nkctb7's Avatar
2006 E55 AMG/1996 C36 AMG/1999 C43/55 AMG/2021 Toyota Tundra Crew Max TRD Sport Premium
After getting robbed this past December, the thieves were back again. They were obviously hoping that everything was replaced and ready for the taking. This time they decided to try to break into my C43 in hopes of moving it from in front of my shed. They jammed a screwdriver into the driver's door lock, completely destroying it. My question is, does this mean that all the locks, ignition, keys, etc. need to be replaced? My keyfob unlocks the door but, the door handle won't open the door. The parts would have to be purchased new from a dealership, correct? Thx
Good thing that I installed two nightvision motion cams last Sunday.
Old Feb 25, 2015 | 09:00 PM
eFifty5AMG's Avatar
2004 E55
Wow. That's awful, sorry to hear. Hopefully the footage will help you get those a**holes off street.
Old Feb 26, 2015 | 05:44 AM
KJI3jflarryfe93's Avatar
sorry to hear about your problems
last time you got robbed, did you have your car at home?
thieves planned to take your car the 2nd time they planned to rob you.
did you install strong spotlights with motion sensors around your property?
you only need to replace door cylinder nothing else
Old Feb 26, 2015 | 08:01 PM
nkctb7's Avatar
What about the issue of the handle not releasing the door when pulled? Also, what about the keys, etc.? Thx
Old Feb 27, 2015 | 05:45 AM
something inside the doorlock or doorhandle mechanism doesn't work properly therefore no reliese
now you have to enter the passengers side everytime.
can you open the drivers door from the inside?
unscrew and remove the doorhandle and lock to inspect possible problems
Old Feb 27, 2015 | 06:44 PM
nkctb7's Avatar
Exactly! The door opens from the inside only as the exterior handle will no longer release. I removed the exterior handles before when I stripped the car down for painting. I was advised by the insurance company to not touch it and have my choice of shop look at it. I would rather do it myself as we all know how certain shops take things apart and reassemble them.
