Renntech CF Intake for M113 for sale
Old Aug 19, 2015 | 11:36 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Originally Posted by SDR
Here's a bunch of pics from when I did my Renntech airbox and ECU tune many years ago:
built to ingest even more hot air I say.the design they did for the 63 box is way superor!!
Old Aug 19, 2015 | 11:40 AM
cm60k's Avatar
+100000001...
ZAYED,,
Old Aug 19, 2015 | 12:05 PM
KJI3jflarryfe93's Avatar
would it help reducing hot air if we wrap the underside on stock airbox with heat resistant foil?
Old Aug 19, 2015 | 12:33 PM
ProjectC55's Avatar
May help a little but still won't be as efficient as the air box setups on the compressor motors
Old Aug 20, 2015 | 01:20 AM
SDR's Avatar
SDR
'99 C43, '12 C63, '13 E350, '14 Sprinter
I'm not sure the air moves through there slowly enough to really be impacted by the engine heat. There's a pretty significant vacuum when these motors are revved and it's pulling air from the front grille. Sure, it's not a cold air intake, but I'm curious just how much it actually heats up along its path. Sounds like a good experiment for a slow weekend
Old Aug 21, 2015 | 10:35 AM
DRBC43AMG's Avatar
Best way to find out is to install a heat sensor close to the throttle body before the air is sucked in the intake. Monitor heat variation when driving then install heat insulation under the box to reduce heat sink and monitor new heat variations when driving. That should explain plenty of things with the pros and cons once and for all.
Old Sep 7, 2015 | 10:33 PM
  #32
speed43's Avatar
1999 C43 Amg
Old Oct 14, 2015 | 04:16 PM
  #33
270win's Avatar
06' E55; 1995 E300D
Did I miss it? What's the price?
Old Oct 15, 2015 | 12:08 AM
  #34
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
Should just be able to use the stock intake air temperature sensor and read on an OBD2 reader. I can add that to my list of things to do one day, haha. You'd need external air temperature to be the same.
