Need help finding heater hose!
Old Jul 31, 2015 | 08:03 AM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
202 832 67 94
It's the long heater hose between aux pump and water pump. Fan poked a hole in it because i didnt seat it properly when doing water pump replacement.
Can't find it anywhere that isnt like 50 or 60 bucks!
Old Jul 31, 2015 | 08:21 AM
cm60k's Avatar
Yeah, It's around ($47)>>($53), from partsdiscount or ECStuning:-
http://www.partsdiscounters.com/oe-m...enz/2028326794
http://www.ecstuning.com/ES1725903/
*or you can put silicone hose, with same ID/OD/Length..
ZAYED,,
Old Jul 31, 2015 | 08:34 AM
Sulaco's Avatar
well, it has 1 90 degree bend at the aux pump...
I was wondering if I could just cut it at the hole and use a piece of nylon piping and 2 hose clamps. would that work?
Old Jul 31, 2015 | 08:48 AM
cm60k's Avatar
Better if you can find alloy connector,
Nylon or Plastic will works, just be sure not over tighten the clamps..!
ZAYED,,
Old Aug 3, 2015 | 10:07 AM
Sulaco's Avatar
plastic coupling kit did not work. I used plastic coupling, rubber cement, and 2 hose clamps, still leaking.
Ordered a new hose today. Got to make sure I seat it properly on the water pump to avoid this issue again!
Old Aug 5, 2015 | 11:10 PM
cm60k's Avatar
Ahh, it's weird Ken., my friend had this issue almost 3 years ago,,
i went to his home & put plastic connector with 2 clamps, no leaks until this moment..!!
ZAYED,,
