1996 Mercedes C36 cps part number
Old Oct 16, 2015 | 09:52 PM
Stevester 500e's Avatar
Mercedes 500e
Hi guys,
I am having a hard time finding the correct part number for my 1996 Mercedes C36's crank position sensor.
AutohausAZ gave me a Bosch part number but the I cross checked it on amazon's "check fit" and it said the AutohausAZ part number was not a fit.
Does anyone have the Bosch part number for a 1996 Mercedes c36 crank position sensor? For a 1996 is the bolt that holds down the sensor a 5mm alen hex or a torx?
I have seen two on the web, one with an integrated cable to it and one without.
Old Oct 16, 2015 | 11:53 PM
cm60k's Avatar
There are "2" types of Bocsh/OEM crank sensors:-
*one comes with (2) Pins connector;-
1) Bosch #: "0261 210 141" or "0261 210 142",
2) OEM #: "003 153 95 28" or "003 153 96 28",
*the other one comes with (1) pin connector;-
1) Bosch #: "0261 210 170" or "0261 210 171",
2) OEM #: "003 153 27 28" or "003 153 28 28",
#pull-out your's, to identify which one you have to go with...
ZAYED,,
