Dutch went to dyno...
Old Jan 26, 2016 | 04:08 PM
PJmak's Avatar
So no secondary cats at all? Have you thought about high flow cats?
Old Jan 26, 2016 | 05:46 PM
DutchC54's Avatar
1998 W202 C43 ///AMG 5.4
no the 1st 2 cats do their job well.
no need to hack/saw more in the system.
sound is good, performance is good .. it wont give me an extra 10 horses so i dont see the benefits of it to change them..
Old Jan 27, 2016 | 10:21 AM
DRBC43AMG's Avatar
As I have done the secondary cats and resonator delete, for each official technical inspection I need to reinstall the OE exhaust, otherwise the inspectors give it a no pass. To avoid this somewhat time consuming procedure, I've been considering taking the secondary cats, gutting them and welding a straight pipe through the canisters and reinstalling them in the system. That way it would look normal. Then I am thinking of installing the OE looking resonator delete pipe (Kowalski has one if I'm correct). See pic below http://www.ebay.de/itm/Mercedes-C43-...item33a4cd11ab
With this set up the inspectors wouldn't probably see the difference. Also I need to change my 18" Monos back the the regular 17". Thankfully my OE wheels have decent tyres to pass the technical inspection. 18" will not pass if the inspector does his work correctly and reads up the homologation and technical docs as the 18"s were never a factory approved wheel size for a C43 nor any other w202 model
Attached Thumbnails Dutch went to dyno...-german-oe-looking-resonator-delete-pipe.jpg
Last edited by DRBC43AMG; Jan 27, 2016 at 10:28 AM. Reason: Added photo of OE looking resonator delete pipe
Old Jan 27, 2016 | 10:40 AM
KJI3jflarryfe93's Avatar
apsolutely correct, Kowalski do have this pipe on his C43.
Kowalski can confirm it's a great buy and highly recommend if you don't want to molest your stock system by cutting it in pieces.
i've heard from other C43 guys who did the 55 swap, coz of bigger displacement from 55 engine, car will sound even more brutal like a lion - Roooooooooarrrrrrrrrrrrrr - with the same pipe
buy it and be happey
it's a great investment for everyone as it's made of HQ german stahl
Old Jan 27, 2016 | 02:15 PM
cm60k's Avatar
^+1^, this connector pipe is Brilliant..
ZAYED,,
Old Jan 27, 2016 | 03:01 PM
PJmak's Avatar
Btw the two pipes that you have now that are running all the way to your muffler, did you just add another pipe and kept it same size as the stock one or did you completely redo everything and ran different diameter pipe?
Old Jan 27, 2016 | 05:04 PM
  #32
DutchC54's Avatar
i did this too..
completely emptied the 2ndairy cats and placed this nice piece perfect fit pipe.
i also have installed these, see the difference in runners compared with stock:
and put in these airfilters, according to another benz forum these should be better then KN:
Old Jan 27, 2016 | 05:09 PM
  #33
DutchC54's Avatar
here is how the first dual pipe system was, with the complete blow thru muffler (made my head hurt..)
i kept the same size piping..
and this is how it currently is installed, so dual piping (no 2ndairy cats) all the way till behind the diff. and then nicely welded into the stock piping of my Original AMG muffler.
so now uve seen all my mods to become to the 394 number
the sound is wicked and just as how it should be.
a very nice deep AMG V8 ROAAAAAAAAAAAAAAAAAAAAAAAAAAAAR.
and like a nice scream when accelerating.
Old Jan 27, 2016 | 05:57 PM
  #34
like a scream in the night, upsetting your neighbours when you hit the throttle!
you might give someone a heart attack?
Old Jan 27, 2016 | 06:05 PM
  #35
DutchC54's Avatar
starting the car when cold is a blast... every nite i try to go to bed early so the sooner its a new morning
ill need to make a coldstart vid now that i write this....
will do so in the coming days..
Old Jan 27, 2016 | 08:17 PM
  #36
sick430's Avatar
CLK Cabrio
WOW, I needed to do this... Thanks for the pictures.
Old Jan 28, 2016 | 04:14 AM
  #37
DRBC43AMG's Avatar
Looking at the photos it seems that the exhaust is in one piece with no flanges somewhere. Could be wrong but...
Also looking at the rear silencer/muffler, I wonder if it is not possible to get the second pipe connected directly to the container instead of connecting to the other pipe. Otherwise looks like a real nice setup
Old Jan 28, 2016 | 04:53 AM
  #38
DutchC54's Avatar
thanks!! and correct ..
indeed the new piping is one piece which, if u want to take off, comes off as one. with the 2 clamps its atached to modified front pipes. (modified so the new piping fits nice and easily onto the front pipes)
u can not just weld into the stock Original AMG muffler because there are made chambers in it. the design of the muffler is specially made for our car.
therefor it has an angle in it. (the huge box gives it that special amg/v8 sound) when installing the open muffler the sound was wayyyyyyyyyyyyyyyy different and totally not like a deep dark tone.
ive thought about installing an E55/W210 muffler because these have 2 inlets, but unfortunatly the box from an E55/W210 is way to big to fit.
(therefor C43 has got this strange looking muffler..it needs room/space to absorb exhaust gasses)
Old Jan 28, 2016 | 04:59 AM
  #39
cm60k's Avatar
Nice & Smart set-up..
ZAYED,,
Old Jan 31, 2016 | 11:56 AM
  #40
DutchC54's Avatar
today 2nd time in a row after i got my car chipped/tuned.
more then 400km on a full tank.. that 1/8!!!!!
so fuel consumption got better after my modified ECU.
this will pay the cost back which i paid for having this done.
Old Jan 31, 2016 | 12:22 PM
  #41
full tank is 62L if i remember correct, do you only cover 400km's on a full tank?
you must have a very heavy right foot?
you should drive in normal conditions in legal speeds to see how much your car drinks?
many years ago i did a fuel consumption check, I covered approx 560-570km's on a full tank.
that was pritty ok i think for lame driving
Old Jan 31, 2016 | 12:53 PM
  #42
DutchC54's Avatar
when my fuel light goes on i visit a fuelstation.
so i allways fill up around 50/53 liters.
remember this is with 5.4 engine not 4.3.
i also must admit i dont do much long distance trips , so for me this a nice extra
with the 4.3 i reached 500+km also when doing long distance trips.
before i got the ecu tweaked i have never reached 400km.
Old Jan 31, 2016 | 01:27 PM
  #43
DRBC43AMG's Avatar
Since I purchased "T Rex", I have averaged 10,58lt per 100km over 71'333km
Old Jan 31, 2016 | 01:35 PM
  #44
with stock c43 ecu and 5.4L engine you only reached approx 400km?
did you drive mixed conditions = old geezer driving/carthief driving?
with the new ecu tweak you reach +500 km?
i thought C43 ecu adapated to the new 5.4L engine and consumption will depend on your driving conditions?
if you drive normal you get normal fuel consumption approx 10L/100km's
Old Jan 31, 2016 | 02:48 PM
  #45
DutchC54's Avatar
sorry, must be my terrible english/or a language thing..
read 4.3/stock C43 i could reach 500km before swapping the engine.
before this i drove for over a year with the stock C43 ecu on a 5.4/swapped engine. and thuss never reached 400km. max i got was like 350/360km.
so now with tweaked ecu my fuel consumption is less i noticed.
i filled, since the tweak, twice now and both times hit the 400+km mark.
btw. i dont think i drive like an avarage guy
when im going to drive like such person ill buy a C180
anyway in the end the ecu adjustment shows for me it was worth it.
Old Feb 1, 2016 | 09:57 AM
  #46
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
no way. C250 diesel wagon with a manual transmission!
as soon as I can someday, I would like to import one of these. Preferably in GREEN
Old Aug 8, 2016 | 12:27 PM
  #47
Sulaco's Avatar
yikes, I just did the secondary cat and res delete on mine, but didn't keep the stock parts. what kind of inspection do they do there??
Old Aug 8, 2016 | 12:59 PM
  #48
DutchC54's Avatar
just a normall exhaustgas check.
at a higher rpm lambda must not be higher then 1.03
so between 0.97-1.03
"google translate" http://autoapkkeuring.nl/apk-keuring...ng-roetmeting/
Old Aug 8, 2016 | 01:06 PM
  #49
mickey13's Avatar
1999 AMG C43
Pretty sure they just plug the machine into the computer here and you're good to go if no codes. But who knows, I've been made a fool plenty of times lol.
