Idle/Misfire with C36
Old Feb 12, 2016 | 07:14 AM
zibpka's Avatar
mercedes c220 c36
I have tried with an autocom error code reader and got the following error.
I got some problem with an c36 amg -96
i have runned a diagnostic on it and this is what i got
132 ECU
156 CAN Signal from ETS/ABS Unknow signal
133 throttle position sensor
136 throttle position sensor
I have tried with another throttlebody
i have rewired the engine harness
i have sent the ecu for checking notthing wrong with it. i have tried with another e-gas module. New oxygen sensor
tried with another MAF
The problem started after changing the head gasket
i'm starting to run out of option
Old Feb 29, 2016 | 11:42 PM
markusr15's Avatar
none
well 136 and 136 mean the throttle body is bad.
You swapped the coils and plugs too?
