C43 engine top cover
Old Apr 15, 2016 | 05:44 AM
DRBC43AMG's Avatar
This was talked about some time back, but can someone say which is the ideal solution and best fitting Star to replace the plastic piece of **** which crumbled away...
Old Apr 15, 2016 | 06:10 AM
cm60k's Avatar
I think (Glk) Star will fit perfectly..!
ZAYED,,
Old Apr 15, 2016 | 06:24 AM
DRBC43AMG's Avatar
Thanks Zayed ðŸ‘
Old Apr 15, 2016 | 08:09 AM
cm60k's Avatar
Daniel,
Some guys tried "W221" Star with (85mm), it may better than "Glk" one:-
https://mbworld.org/forums/w210-amg/...ont-cover.html
https://mbworld.org/forums/c36-amg-c...over-star.html
https://mbworld.org/forums/c36-amg-c...ml#post4497403
ZAYED,,
Old Apr 15, 2016 | 08:28 AM
speed43's Avatar
1999 C43 Amg
If any of those stars have the plastic "pins" that go inside the 3 holes. You can use a soldering gun to melt the top of these pins to the side and it will hold without using any glue. Just press the star flush to the cover and heat the tip pushing to the side. Takes about 40 seconds or less.
Old Apr 16, 2016 | 09:18 PM
Vicious_c43's Avatar
'98 AMG C43 / '70 Cougar
https://mbworld.org/forums/c36-amg-c...ml#post6060121
Did this project last year....still on there shining like a diamond
Old Apr 17, 2016 | 05:11 AM
DRBC43AMG's Avatar
Thanks for the link to your DIY. Perfect!
Old Apr 19, 2016 | 12:53 PM
No prob...awesome! should be an easy project
Old Apr 20, 2016 | 10:44 AM
DRBC43AMG's Avatar
Yeah, I got the Star yesterday but had to part with CHF32.- which is about the same in $
OK I did get the three plastic pins to pinch up between the Star and under the cover included...
Old Sep 22, 2016 | 06:23 AM
DRBC43AMG's Avatar
A quick follow-up on this job.
Using the Star # A 211 758 00 58, it just doesn't fit right You can see the original star ridges on the engine cover.
Measurements
Engine cover:
External diameter 82mm
Internal diameter 71mm
Star:
External diameter 85mm
Internal diameter 76mm
Need something smaller....
