Nurburgring 2016 trip
Old Jun 19, 2016 | 04:06 PM
DRBC43AMG's Avatar
How much negative do you want?
Old Jun 19, 2016 | 04:39 PM
raw1879's Avatar
Mercedes C55 AMG
around 2.5 degrees as the tyres I have start working at 2 degrees
Old Jun 21, 2016 | 11:51 PM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
What was the crunching sound? Sounded like the suspension crashing.
Old Jun 22, 2016 | 03:49 AM
raw1879's Avatar
Mercedes C55 AMG
the only sound I can hear is tyre rub 🤕
Old Jun 22, 2016 | 04:00 AM
DRBC43AMG's Avatar
I have a similar sound when hitting waves on the road with two people sitting in the back. This occurs with my 18" Monos and the KW Variant II suspension all round. With 17" no rubbing at all.
Old Jul 9, 2016 | 06:39 AM
raw1879's Avatar
Mercedes C55 AMG
Diff
Used diff only cost £100
Diff oil cooler going to mount in middle of rear diffuser
Oil cooler kit seem good quality I also have a mocal pump
Old Jul 9, 2016 | 06:56 AM
  #32
cm60k's Avatar
One of great idea, what kind of oil pump will use with it..??
,,ZAYED,,
Old Jul 9, 2016 | 08:50 AM
  #33
raw1879's Avatar
Mercedes C55 AMG
This one it's a mocal oil pump
Old Jul 9, 2016 | 10:03 AM
  #34
DRBC43AMG's Avatar
Your pump looks very similar to the Mocal I'm installing in my Ultima build which is connected to a 996/50 TT Porsche box.
Do you have an idea what's the running temp of the diff when you are driving the Ring or other hard driving instances. I've been told that the cooler is not necessary unless you are tracking a lot. The LSD also adds extra heat in the diff.
I assume you are using a high grade fully synthetic oil. That should also be changed regularly.
Attached Thumbnails Nurburgring 2016 trip-s7003972-mocal-oil-rad.jpg   Nurburgring 2016 trip-s7003973-mocal-oil-pump.jpg
Old Jul 9, 2016 | 02:23 PM
  #35
raw1879's Avatar
Mercedes C55 AMG
Yeah cool it's the same pump
I'm don't know what the diff temps get to on track all I know is it get too hot to touch.
Old Jan 11, 2017 | 08:48 PM
  #36
sick430's Avatar
CLK Cabrio
I know this thread is a little old, but I just broke my rear diff.
Are there any more pictures of the cooler install? Thanks
Old Jan 12, 2017 | 05:17 AM
  #37
DRBC43AMG's Avatar
Yeah and what's new or going on with the beast raw1879??
Old Jan 12, 2017 | 08:41 AM
  #38
KJI3jflarryfe93's Avatar
how did you manage to poop your diff?
Old Jan 12, 2017 | 07:16 PM
  #39
sick430's Avatar
CLK Cabrio
55 swap, a few other goodies and a very heavy right foot Not sure how bad it is inside. I will most likely take in out over the weekend and see what it looks like.
Anyone have any suggestions on upgrading the rear?
Old Jan 12, 2017 | 07:32 PM
  #40
must be shrapnel inside diff housing?
do you toast your tires in front of the local hamburger joint?
one day your diff will blow up and it has now unfortunately happened
the CLK430 diff is it the same from C43AMG - 3.07???
Old Jan 12, 2017 | 07:46 PM
  #41
cm60k's Avatar
I believe "Clk430" comes with "2.87", with the same C43 housing, which is (185mm),
with 55 swap, prefer to go with "2.82", (210mm) housing from "W208 Clk55",
or if you have EGS52, you can go with "3.06", (210mm) housing from "W203 C32/C55 or W209 Clk55 or R171 Slk55",,
which is IMO; better ET's & better performance..
;ZAYED;
Old Jan 13, 2017 | 06:20 AM
  #42
;ZAYED;
Zayed
if I happen to blow my diff in the future???
would w208 clk55 - 2.82 diff fit with stock C43 ECU/TCU?.
only thing to do is to cut the plate inside trunk above pumpkin like Pagz did to make room for the new diff?
Old Jan 13, 2017 | 09:19 AM
  #43
cm60k's Avatar
unfortunately; can't go with any differ Ratio if we still using EGS51, have to stick with "3.07"..!,
Paul(Pagz) swapped almost everything from donor "W208 Clk55", with big "W220" pumpkin & EGS52,
all "R170 & W208" sharing the same sub frame with "W202",,
Except "W208 Clk55", due to the "W220" big gear/pinion & pumpkin..
;ZAYED;
Old Jan 21, 2017 | 07:53 AM
  #44
raw1879's Avatar
Mercedes C55 AMG
[img]webkit-fake-url://9f033914-9a6f-4ca7-b65a-ea327d8d055a/imagejpeg[/img][img]webkit-fake-url://28593561-fba2-499a-aa65-e4da47829671/imagejpeg[/img][img]webkit-fake-url://d630ec7d-6b25-499e-9a89-dcb413a6c1ee/imagejpeg[/img]
Old Jan 21, 2017 | 11:57 AM
  #45
DRBC43AMG's Avatar
Hmmm, says a lot of "webkit-fake-url" but I don't think we speak this computer lingo..., well I can't, neither can my computer
Old Jan 21, 2017 | 12:01 PM
  #46
cm60k's Avatar
+1, Nothing showing-up..?!?!?
-;ZAYED;-
Old Jan 21, 2017 | 02:46 PM
  #47
raw1879's Avatar
Mercedes C55 AMG
[img]webkit-fake-url://6a2057af-d9c6-430d-8167-445d4d98f27c/imagejpeg[/img]
Old Jan 21, 2017 | 03:44 PM
  #48
DRBC43AMG's Avatar
Nope, still nothing.....
Old Jan 21, 2017 | 04:25 PM
  #49
raw1879's Avatar
Mercedes C55 AMG
Old Jan 21, 2017 | 04:26 PM
  #50
raw1879's Avatar
Mercedes C55 AMG
Talking
Now I know how to up load from my phone
