MAF and check engine light?
heh besides that I love the car. It's a obsidian black with two tone interior. And i got it from a fellow mbworld.org member!
Hey there, are you by chance the same "knvs" from the VWVortex forums? Anyway, if you are in the SF Bay Area I have a generic OBDII scanner so at least you can see what codes come up. Let me know.
Also is it bad to drive around with a bad MAF if it is, or will it be ok til tues. How bad is a vaccume leak? how bad is it to fix (cost)? Could it be O2 sensors? it also bogs in idle, it revs from 500-700 and not smooth when i coast under 20 mph. But when i get to higher speeds it's ok.
g_char@yahoo.com
